| | Lt1 water pump install question | |
| Subject: Lt1 water pump install question Sat Aug 31, 2013 4:28 pm | |
| Anyone know if you need the little seals that go in front and back of the drive coupling?
When I pulled the WP off the lt1 while cleaning a very thin round seal seated against the water pump spline. After reading the FSM it looks like there's supposed to be 2 of them, one on each side in between the coupler and WP/drive My gasket set didn't have them nor were they listed on the package. Sooo I installed NONE, Anyone doing opti's come across this? Any issues?
| | | 95brmw
| Subject: Re: Lt1 water pump install question Sat Aug 31, 2013 8:25 pm | |
| The Felpro timing cover kit usually comes with them (2 I think). There is suppose to be one on the pump and one on the drive shaft. I've installed the pump without them, never had an issue. | |
| | | Ironfistdog
| Subject: Re: Lt1 water pump install question Sat Aug 31, 2013 8:36 pm | |
| That's what I bought, felpro. You are talking about 2 paper circle gaskets right? My kit came with:
1 front crank seal 1 opti drive seal 1 dreaded water pump drive seal 1 paper timing cover seal 2 water pump to block seals 2 rubber o-rings for the opti
| | | 95brmw
| Subject: Re: Lt1 water pump install question Sat Aug 31, 2013 10:02 pm | |
| - Ironfistdog wrote:
- That's what I bought, felpro. You are talking about 2 paper circle gaskets right?
My kit came with:
I was talking about the O-rings. They work for either the pump or the opti, but I feel their more useful on the opti if those are all you have. | |
| | | Ironfistdog
| Subject: Re: Lt1 water pump install question Sat Aug 31, 2013 10:09 pm | |
| So the paper gaskets can be thrown away then? I don't even seen them Listed for sale or mentioned anywhere, | |
| | | 95brmw
| Subject: Re: Lt1 water pump install question Sun Sep 01, 2013 9:16 am | |
| I don't recall getting any paper circle shaped gaskets with my last kit, can't think of what they would be used for. | |
| Subject: Re: Lt1 water pump install question | |
