275/60-15 Nitto 555 Extreme EmptyWed Oct 19, 2022 1:27 pm by scot
275/60-15 Nitto 555 Extreme EmptyTue Oct 18, 2022 8:58 pm by silverfox103
275/60-15 Nitto 555 Extreme EmptyTue Sep 28, 2021 11:01 pm by silverfox103
275/60-15 Nitto 555 Extreme EmptyFri Sep 24, 2021 9:53 am by ElKy
275/60-15 Nitto 555 Extreme EmptySun Sep 19, 2021 6:22 pm by black blur 96
275/60-15 Nitto 555 Extreme EmptySun Jun 20, 2021 11:37 am by scot
275/60-15 Nitto 555 Extreme EmptyFri Jun 11, 2021 10:41 am by scot
275/60-15 Nitto 555 Extreme EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
275/60-15 Nitto 555 Extreme EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
3 posters
scot
PostSubject: 275/60-15 Nitto 555 Extreme   275/60-15 Nitto 555 Extreme EmptySun Aug 14, 2016 1:09 pm
15's ! Now available in the states, my daughter got hers from TireBuyer. Vastly better than any other the same size from other manufacturers. Only in 275/60 in a 15".
booth9C1SS
booth9C1SS
PostSubject: Re: 275/60-15 Nitto 555 Extreme   275/60-15 Nitto 555 Extreme EmptySun Aug 14, 2016 1:54 pm
I've run 255/60R15 before and liked them. Same size at the impala ss 255/50R17.
How tall are the 275/60? Are they close to the 225/70R15? I have the 8" van rally wheels, so wider rubber would look good... but I don't want to have to reprogram the pcm for the speedo to be correct.
scot
PostSubject: Re: 275/60-15 Nitto 555 Extreme   275/60-15 Nitto 555 Extreme EmptySun Aug 14, 2016 2:04 pm
275/60-15 is a 28" tall tire and is ideal on 8" wheels. You can used it on 7" wheels. The tire co. always say you need 7.5's but no one has a problem on a 7". On a 9C1 car in the rear you will find a 1/4" or up to 3/8" spacer between the wheel and hub will prevent tire rubbing on the frame. The 9C1 speedo is calibrated for a 28" tire (225/70-15) The spacer requires replacing the two rear hubs lugs with correspondingly longer studs. Cheap from Autozone and others, easy and widens your track 1/2 to 3/4" for a little handling uptick. Wide-Track flashback.
Chris Klein
PostSubject: Re: 275/60-15 Nitto 555 Extreme   275/60-15 Nitto 555 Extreme EmptyWed Jun 09, 2021 9:41 pm
I currently have a set of Nitto NT555R on my car. I got it from 4WheelOnline a few months ago. I like the excellent grip and traction that this tire provides.
» Feeler: 4 Nitto NT555 Extreme ZR on SS wheels
» Nitto 555s
» NITTO DRAG RADIALS
» LT4 Extreme Duty Timing Chain Kit Brand New
