| Air pump delete | |
+3MASShole9C1 fatvet nttyfufu 7 posters |
nttyfufu
| Subject: Air pump delete Tue Feb 28, 2012 3:34 pm | |
fatvet
| Subject: Re: Air pump delete Wed Feb 29, 2012 2:58 pm | |
| this is one my todo list also....
please document as much as you can AFA the gotchas.....
i heard that metal tube that goes across under the motor is a PITA to get out in one piece ...
-ALF out... | |
| Subject: Re: Air pump delete Wed Feb 29, 2012 3:24 pm | |
| I have no plans on doing this to my 9C1, but my L99 car had it done buy the previous owner. Im not sure who thought is was the best idea to weld over the threads where the pipes go into the exhaust manifold instead of installing those bolts. He even unplugged the check engine light bulb so I wouldnt notice | |
| Subject: Re: Air pump delete Wed Feb 29, 2012 3:37 pm | |
| I dont think that tube comes out in 1 pc unless you pull the motor I just zipped it in 1/2 , wiggled it until the tab broke & out it came | |
fatvet
| Subject: Re: Air pump delete Wed Feb 29, 2012 3:53 pm | |
- I dont think that tube comes out in 1 pc unless you pull the motor
I just zipped it in 1/2 , wiggled it until the tab broke & out it came aaahummmm.......you need to know what you are doing..... post #29 http://www.impalassforum.com/vBulletin/showthread.php?t=229732&highlight=air+pump+delete -ALF out.. | |
nttyfufu
| Subject: Re: Air pump delete Wed Feb 29, 2012 4:39 pm | |
| I have defenetly heard the same about that pipe. It makes me wanna try to do just to see if I can. @ Alf notice in your pic the pipe is cut on the far left Between the end and the tab( but I agree I have also heard you can do it in one if you know how). And when I do the bottom stuff I will document as best I can but it may not be for a while it's snowing out so driveway laying is not in my future. | |
| Subject: Re: Air pump delete Wed Feb 29, 2012 4:46 pm | |
| OK yes, if you want to spend LOTS of time & disassemble WAY more then just the Air system I guess you could. I wouldnt & I'm betting you wont either.. I thought to myself...will I ever put this back in?...NO...zip...it's out | |
| Subject: Re: Air pump delete Wed Feb 29, 2012 4:48 pm | |
| I did that on my 9C1 but left the pipe in there. I know, very half-assed. I did it mainly because I was too lazy to put the air pump that didn't work back in after doing a WP job. Luckily for me it had been deleted out of the programming on the computer already. Gotta love OBD II lol. | |
nttyfufu
| Subject: Re: Air pump delete Wed Feb 29, 2012 6:46 pm | |
| @ sdstick ya I said I'll try but it will most likely end up in pieces. I garentee(sp?) that after trying for 15 min I'll say the same thing "Is it ever going back in... nope cut cut cut" . | |
| Subject: Re: Air pump delete Wed Feb 29, 2012 8:47 pm | |
| I'd do it, it's just the problem of having it programmed out. Don't know where to get it done. To hell with the dealer, they have no idea what to do, even tho its a TSB . Been there, done that! | |
| Subject: Re: Air pump delete Wed Feb 29, 2012 10:21 pm | |
| 95 just leave the relay & fuse in.....no cel | |
| Subject: Re: Air pump delete Wed Feb 29, 2012 10:29 pm | |
| Not true. The previous owner "did it" on my 95 and the light is still on. When I scanned it with the tech II the code is for the AIR.
I'd need to do it for a '96 tho. | |
| Subject: Re: Air pump delete Wed Feb 29, 2012 10:33 pm | |
| Well I did it MYSELF to my 95....no cel Check & make sure the relay & fuse are there (& good) | |
| Subject: Re: Air pump delete Wed Feb 29, 2012 10:38 pm | |
- Well I did it MYSELF to my 95....no cel
Check & make sure the relay & fuse are there (& good) OK thanks! | |
| Subject: Re: Air pump delete Wed Feb 29, 2012 10:40 pm | |
| Also worked on my 95 RMW so the impala wasnt a fluke. | |
nttyfufu
| Subject: Re: Air pump delete Thu Mar 01, 2012 4:15 pm | |
| Sdstick is correct no cel on 94-95. The key is you NEED TO LEAVE THE RELAY IN PLACE. then it will be fine,no reprog. needed. | |
| Subject: Re: Air pump delete Thu Mar 01, 2012 7:23 pm | |
| OK, When the snow goes away, Ill check the relay and fuse for it. Thanks! | |
| Subject: Re: Air pump delete Fri Mar 02, 2012 8:23 am | |
| ditto my 94 has it out but relay and fuse in no MIL | |
Check & make sure the relay & fuse are there (& good) you made a goof its a MIL not CEL lol | |
| Subject: Re: Air pump delete Fri Mar 02, 2012 8:28 am | |
you made a goof its a MIL not CEL lol ACTUALLY.....there was NEITHER | |
| Subject: Re: Air pump delete Fri Mar 02, 2012 8:34 am | |
chapel
| Subject: Re: Air pump delete Sat Mar 03, 2012 1:12 pm | |
| I just looked at mine. it's still all hooked up. I have the early system, so I need that big bolt to jam in there... what's the cap size for the airbox? | |
| Subject: Re: Air pump delete | |
| Air pump delete | |
