 EGR tube delete
PostSubject: EGR tube delete   Thu Dec 15, 2011 7:07 pm
anyone done this? I'm sure there is!! I know i'll get a check engine lite. Mine is leaking, I bought a new one before they went disco from GM. My secong thought is to remove it all together.
PostSubject: Re: EGR tube delete   Thu Dec 15, 2011 9:20 pm
Block off plate kit on eBay,
Need to tune it out in the PCM.
I hear alot say dont do it.
I used afterburners without EGR so off it came.
Leave the solenoid plugged in & there's no CEL
It can be programmed out.
PostSubject: Re: EGR tube delete   Fri Dec 16, 2011 8:41 am
i blocked the left side off when i did headers. i just made a new plate with 1/8" steel drilled a couple holes and made a gasket for it. took 45 mins..
EGR tube delete
» Quick troubleshooting guide for Dynaco tube amps
» 2"Burrell Smokebox tube / smokebox door ring
» Tube Rolling with the ST120
» A/C delete pully
» Mechanical Fan Delete
