| Author | Message |
 | Subject: Mechanical Fan Delete Mon Feb 14, 2011 5:22 am | |
| Hey Wagon guyz Can I just delete the mechanical fan? Or do I have to add Dual electrics? Finally have the wagon running good enough to hear the noise....I'm not impressed. Plus I'm sure I can buy some mileage which I'm always happy with. I didnt do alot of searching. |
Posts: 674 Join date: 2009-02-02 Age: 24 Location: Easton MA
 | Subject: Re: Mechanical Fan Delete Mon Feb 14, 2011 5:33 am | |
| There's already a secondary electric fan.. You'll need an electric fan and shroud. Order the wiring harness online. I removed mine and ran it all last fall with only the secondary fan. Temp only climbed once, while in traffic. I have the primary electric fan, and fan shroud in place on the car. I still have to order the harness. You'll also need shorter bolts for the water pump to fully delete it. |
Posts: 2368 Join date: 2009-02-21 Age: 39 Location: Midcoast Maine
 | Subject: Re: Mechanical Fan Delete Mon Feb 14, 2011 7:07 am | |
| Hmmm, i know where there are a bunch of 9c1 lt1 fan set ups, damn it whats that guys name? |
 | Subject: Re: Mechanical Fan Delete Mon Feb 14, 2011 10:37 am | |
| :-) I'm gonna need a bigger truck this weekend. |
Posts: 862 Join date: 2009-01-25 Age: 18 Location: Littleton, New Hampshire
 | Subject: Re: Mechanical Fan Delete Mon Feb 14, 2011 11:14 am | |
| Hi Steve
I converted my RMW a few years ago, pretty easy job. I wasn't pressed to get it back in service.
These are the directions that I followed, great write up: http://www.theherd.com/forum/topic.asp?TOPIC_ID=49
You do not need to reprogram the PCM, I did though, to drop the temperate that the fans would turn on. I believe it is around $100, actually maybe a little more.
Now my 2 cents, if the wagon is your "winter car", I would leave it as is. You will be doing enough repairs on it.
Tom _________________ 1994 RMW LAB---my toy from FL 139,000 1994 Caprice Wagon---Never seen winter, 104,000  |
booth9C1SS
Posts: 129 Join date: 2009-01-24 Age: 37 Location: Wayne, ME
 | Subject: Re: Mechanical Fan Delete Mon Feb 14, 2011 12:57 pm | |
| | No Moa wrote: | | :-) I'm gonna need a bigger truck this weekend. |
You mean that you need a wagon.
This won't affect flow or anything, but the dual electric fans caprices came with a different lower radiator hose. It is a one piece rubber (or silicone) hose from radiator to the water pump. The mechanical setup has a metal section in the middle of two rubber hoses. This metal part a) protects the hose from the nearby fan blades, and b) anchors that section to the engine.
 | Subject: Re: Mechanical Fan Delete Mon Feb 14, 2011 1:00 pm | |
| No that's the last thing I need. |
Posts: 1922 Join date: 2009-01-19 Age: 24 Location: Pawtucket, RI / Hyannis, MA
 | Subject: Re: Mechanical Fan Delete Mon Feb 14, 2011 1:08 pm | |
 | Subject: Re: Mechanical Fan Delete Mon Feb 14, 2011 1:20 pm | |
| | GasTT wrote: | | Yea Glen u need a waagon |
Lmao |
 | Subject: Re: Mechanical Fan Delete Mon Feb 14, 2011 1:48 pm | |
| U can pull the mechanical off and run it with just the secondary through the winter. We can program that to be like the primary, if you want, as long as it is a 95. You can take your time to swap over the electric stuffs.  _________________ Bill "The Verb" Crovo - Resident Car Slut 04 CTS-V -The Big Bad Wolf- 500RWHP, Maggie, Kook's, Magnaflow, etc... 95 White WB4 "GS" -The Marshmallow- Lotsa stuff done, lots more to come... 00 Sierra 2500 ECSB -The Big Slut- H2's & 33's, TB crank, CAI, Magnaflow, Cowl'd, etc... 94 Miata- Project Cone Killer- Manual everything. No cone is safe. No more Subarus. Ever. EVAR! American Ricerwww.badassofne.net "Ooooh! Look! Something shiny!" |
 | Subject: Re: Mechanical Fan Delete Mon Feb 14, 2011 2:06 pm | |
| | toomanytoyz wrote: | U can pull the mechanical off and run it with just the secondary through the winter. We can program that to be like the primary, if you want, as long as it is a 95. You can take your time to swap over the electric stuffs.  |
Who in the club can tune?? |
 | Subject: Re: Mechanical Fan Delete Mon Feb 14, 2011 2:14 pm | |
| I have tunercat, but don't know enough to "tune" per se... But I can adjust fan temps and adjust your speedo and stuff on OBD1 cars.
 | Subject: Re: Mechanical Fan Delete Mon Feb 14, 2011 2:23 pm | |
| Thanks for the info & offer of programming help. I do have plenty to do, but that mechanical fan is so....so .....yesterday. It also takes up way to much room under the hood. This car will be the work horse year round. It'll just get alot less use in the summer. |
Posts: 919 Join date: 2011-03-01 Age: 31 Location: Hyannis, ma
 | Subject: Re: Mechanical Fan Delete Sat Mar 05, 2011 3:25 am | |
| | toomanytoyz wrote: | I have tunercat, but don't know enough to "tune" per se... But I can adjust fan temps and adjust your speedo and stuff on OBD1 cars.
what you want to get rid of speed limiter on mine and maybe tune out the pass key fault light and abs system send me a pm cant really afford to buy tuner cat right now
Last edited by mega on Sat Mar 05, 2011 3:25 am; edited 1 time in total (Reason for editing : add) |
