Stumble help. EmptyWed Oct 19, 2022 1:27 pm by scot
Stumble help. EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Stumble help. EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Stumble help. EmptyFri Sep 24, 2021 9:53 am by ElKy
Stumble help. EmptySun Sep 19, 2021 6:22 pm by black blur 96
Stumble help. EmptySun Jun 20, 2021 11:37 am by scot
Stumble help. EmptyFri Jun 11, 2021 10:41 am by scot
Stumble help. EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Stumble help. EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 Stumble help.
3 posters
Stumble help. Empty
PostSubject: Stumble help.   Stumble help. EmptySat Oct 23, 2010 8:32 pm
The 9c1 has a small issue. When you give it throttle, it will stumble and then clear out and go. This is just a slight stumble, but still a stumble. I know the opti is good. Pretty sure the wires are. I left the plugs in. Any Ideas?
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 8:46 pm
With the TPS being a potentiometer, it can get dead spots. It may be stumbling at a spot it consistantly rides at. Check its resistance with OEM specs
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 8:51 pm
It only does it in gear driving. In park, it revs fine. I probably know the answer, but my head is so full crap, I can't think.
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 8:59 pm
Light throttle? EGR?
Regular throttle? TPS? IAC reset? TBS cleaning? Plugs? Vacuum leaks?
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:03 pm
yes
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:05 pm
yes
BINGO! Thanks guys. Wink
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:30 pm
yes
Basketball all in a days work
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:41 pm
IAC reset?
scratch Is this something I can do? What is involved?
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:45 pm
Im guessing you need a scan tool
http://www.gnttype.org/techarea/faq/IACresetscan.html
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:46 pm
IAC reset?
http://shbox.com/1/4th_gen_tech2.html#iac_reset
Depress accelerator slightly
Start engine, then release accelerator pedal, run engine for 5 seconds
Turn ignition "OFF" for ten seconds
Restart engine and check for proper idle operation
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:49 pm
IAC reset?
I don't remember, but I know it's quick and easy. Normally that's for an idle issue anyways, but figured that it could be something worth checking if plugs and a TB service didn't clear it up... Wink
EDIT: See, I walk away for a couple minutes before I hit send and someone figured it out already... Very Happy
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:51 pm
mean ss wrote:
IAC reset?
LOL i just got done reading that study ...im dumb Question
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:58 pm
mean ss wrote:
IAC reset?
what you had posted is more for adj. the throttle blades by IAC counts but we want them in the 30's
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 10:13 pm
I figured as much. I took a quick glance, posted, then found what you posted
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptyWed Oct 27, 2010 3:07 pm
Ok
I found the IAC valve was no good. I replaced it with another one I got from crovo, along with completely rebuilding the TB out of spare parts. Now she runs like a champ. cheers
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptyMon Nov 01, 2010 9:57 pm
Ok
I was wrong. Wound up being the EGR after further diag.
Stumble help. Empty
Stumble help.
» Off the line stumble
» Bad stumble/misfire
» Cold engine stumble, with drivers little backfire
» Stumble and surge Any ideas? My head hurts
» Stumble/surge issue at Operating tempuratre at idle. Help.
