» Mass refugee now in Pa
» 1996 DGM RMW
» Roundup pics?
» Looking for exhaust part
February 2019
 Bad stumble/misfire
PostSubject: Bad stumble/misfire    Thu May 28, 2015 7:59 pm
(Obviously much diag is ahead, but I'm in the early stages of working this out, so here's a thread)
The roadmaster (94 LT1) has developed a strange miss/stumble. It's not consistent with weather (Wet/dry hot/cold). I've had 2 times this week where it didn't fire right away after sitting overnight. It started, but still unusual. Everyone jumps on opti being the issue, but I'm not gonna throw darts at $$$ parts. I've been reading the last 6 years about this stuff and it can be anything from the fuel pump, filter, and injectors being clogged, to fouled O2 sensors, intake leak, clogged cats, etc. I have no way to datalog and haven't checked the fuel pressure yet. I know the filter needs replacing. This happened after someone filled my gas tank with 87 from Cumberland farms. I always run shell gas. I put gumout in the tank and nothing really changed. Seems like it's getting worse. I've done no (ignition) tune up related work to this car. Thoughts before I part it out? I can't spend a ton of $ on this car to keep it going. It's not worth it. Anybody local have OBD-I data logging capabilities??
Thanks!
PostSubject: Re: Bad stumble/misfire    Fri May 29, 2015 10:33 am
You say this happened after someone put 87 octane in it
Nothing wrong with 87 but I'm assuming youre thinking water in the gas?
If so...have you burned through that tank & refilled yet?
Is the gumout youre talking about drygas?
PostSubject: Re: Bad stumble/misfire    Fri May 29, 2015 10:38 am
I didn't run the tank down, but I since put $20 worth and it's on E now. I put a bottle of system cleaner in the tank when it was 1/2 full on the gauge.
The timing is perfect with that full tank of gas and I had ZERO performance/running/driving issues prior.
PostSubject: Re: Bad stumble/misfire    Fri May 29, 2015 11:08 am
If it were me, I'd put some drygas & octane booster in there & run it through with some good gas.
Car will run better then ever (at least for that tank) & even though you pissed through $10-$15 extra it'll clean out some shyt
THEN....fuel filter for sure...just cuz youre due from the sounds of things.
If its rusted in & you cant change it, confirm pressure instead.
NEVER seen a filter cause the issue.....
Ya, I know, the friggin experts say it can happen..Rolling Eyes
Sure, you should search out other stumble issues (dirty TB, MAF)..do the free ones first
I also see you have someone gonna be looking for arcing wires...thats good.
If I were throwing darts, I'd aim at the opti & oil thru the seal only because the odds are in my favor.
You can open & clean & re-install for only the cost of front cover gasket set but its a PIA if you need the car as a daily.
Whomever borrowed your car....Do they have a big heavy right foot?.. Laughing
PostSubject: Re: Bad stumble/misfire    Sat May 30, 2015 6:41 pm
Start with running TECHRON through it. Nothing else compares to that stuff. I've seen a car that ran a few bottles of that then the head was pulled off (cam & lifter issue) and those valves were efin clean. You could eat off them. Use that.
Then start to look into it if it continues. The hard start after sitting overnight makes me think of a bad FP or press. regulator letting pressure bleed down. I would just hook up a gauge and check to be sure.
Steve is on the right track obviously, free stuff first clean the MAF and TB and of course try to pull an arc off a plug wire with a test light.
PostSubject: Re: Bad stumble/misfire    Sun Jun 07, 2015 11:02 pm
Ran HEET and gum out through a full tank of fresh Shell gas. Was foolish and thought it had started running better.
Wrong. Finally had a night at home where I was able to check the car out. Actually brought the car to my buddy's house 4 houses down to drop off some scrap metal. It was dark out so we decided to spray some water on all the ignition components while the engine was running. Sure enough, we had a nice pre 4th of July show on our hands.
From the coil all the way to the wires we have about 1/2 a dozen or more areas arcing. Plus one of the Champion plugs was gapped at .070. Lol.
My fault since I never did plugs or anything to this car since I bought it October 2013. I'm sure after I replace the plugs, wires, and coil, I'm gonna have some other drivability issues. Seems common enough with the L99/LT1 cars.
Also found that the car overheats while idling and the fans don't turn on unless you unplug the temp sensor in the pump.
Any thoughts?
PostSubject: Re: Bad stumble/misfire    Mon Jun 08, 2015 9:23 pm
What do you consider overheating? The LT1 fans come on at a very high temp from the factory.
PostSubject: Re: Bad stumble/misfire    Mon Jun 08, 2015 10:01 pm
Overheating as in, can smell coolant from reservoir and fans don't come on when roadmaster gauge is at 3/4 or higher.
miniz33
miniz33
PostSubject: Re: Bad stumble/misfire    Tue Jun 09, 2015 10:29 pm
Double check the coolant temp sensor with an ohm-meter, any discrepancy will throw these obdI lt engines off by a landslide, including driveability and fan problems.
PostSubject: Re: Bad stumble/misfire    Tue Jun 09, 2015 11:42 pm
True. Very true. Had a bad CTS in a 95 Caprice I had a few years ago. It was waaaayyyyyy out of spec for the 75* ambient temp at the time.
Didn't even consider it for this car since I literally replaced it a year or so ago when I did the WP. I'll check it out in the day light tm. I'll report back.
Tks!
Bad stumble/misfire
» Off the line stumble
» Stumble help.
» As newspapers stumble online, will we lose our local news?
