found the problem. EmptyWed Oct 19, 2022 1:27 pm by scot
found the problem. EmptyTue Oct 18, 2022 8:58 pm by silverfox103
found the problem. EmptyTue Sep 28, 2021 11:01 pm by silverfox103
found the problem. EmptyFri Sep 24, 2021 9:53 am by ElKy
found the problem. EmptySun Sep 19, 2021 6:22 pm by black blur 96
found the problem. EmptySun Jun 20, 2021 11:37 am by scot
found the problem. EmptyFri Jun 11, 2021 10:41 am by scot
found the problem. EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
found the problem. EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 found the problem.
4 posters
PostSubject: found the problem.   found the problem. EmptyMon Aug 03, 2009 9:29 pm
As some of you know, I put a junk yard LT1 in my wagon last year. After a week, I had an engine noise and had to get another engine. I found the problem.
Installing replacement engine
http://www.impalassforum.com/vBulletin/showthread.php?t=201304
Replacement engine failure
http://www.impalassforum.com/vBulletin/showthread.php?t=205552
Second replacement engine
http://www.impalassforum.com/vBulletin/showthread.php?t=206517
This is what I found yesterday. Number 7 spun one fo sho!
found the problem. DSCI0108
found the problem. DSCI0114-1
found the problem. DSCI0113-1
found the problem. DSCI0115-1
PostSubject: Re: found the problem.   found the problem. EmptyMon Aug 03, 2009 9:58 pm
That's a good bit of damage there. What was the cause of the spun bearing? Did you forget the oil Wink
PostSubject: Re: found the problem.   found the problem. EmptyTue Aug 04, 2009 5:48 am
Damn, that sucks. Just what you need another project.
Time to send Doug out with a mission
PostSubject: Re: found the problem.   found the problem. EmptyTue Aug 04, 2009 9:22 am
Hi Bill
This is the old problem from the wagon, right; not a new problem from the Impala, I hope?
PostSubject: Re: found the problem.   found the problem. EmptyTue Aug 04, 2009 12:06 pm
Hi Bill
Old problem from the wagon. I went over to my inlaws house to grab the engine and I decided to do a partial teardown. Later down the road, I am going to rebuild this one. I will probably need a new crank, or some big bearings.
PostSubject: Re: found the problem.   found the problem. EmptyTue Aug 04, 2009 5:52 pm
Dat rawght thare cood be yur prablem!
Bummer.
Mobil 1 would fix it. Wink
PostSubject: Re: found the problem.   found the problem. EmptyTue Aug 04, 2009 6:22 pm
Bummer.
I did use mobil 1
I can only think I may have gotten something lodged in the oil passage replacing the gaskets. scratch
Either way, there it is. Evil or Very Mad
found the problem.
» Air Dam Problem
» an odd ABS problem
» Problem with ?
» Different day SAME problem
» My car just started fing up REAL bad.
