 Different day SAME problem
PostSubject: Different day SAME problem   Mon Mar 07, 2011 5:28 am
I cant believe it. This really underminds me and my diag as a tech. So, its been raining alot here, the Caprice hasnt been driven all weekend, and now it doesnt start...AGAIN! All it does is crank, and crank. The opti, plugs, wires, and coil have just been replaced like, 2 weeks ago. Maybe water is getting on the PCM or something when it rains. Im stumped at this point. Surprised Im going to drive one of the other cars to school, and look into it when I get home later.
PostSubject: Re: Different day SAME problem   Mon Mar 07, 2011 6:07 am
Did you use grease on all connections & sealer on the cap?
I see ALOT of posts where moisture fights you for control of the electrical system.
When my 95 opti went (stock 90K) thats all that happened.
Would work day in & day out but come rainy days the crank & no start occured.
I only let it go 2 times (in fear of stranding).
Not saying you didnt do it right, so I'd look elsewhere.
Coil connector?
Might be time to scan it
PostSubject: Re: Different day SAME problem   Mon Mar 07, 2011 6:15 am
I'll check around today. I cant scan it. Its a 95. The last OBDI B body I scanned with a jumper wire, the cooling fans turned on and the check engine light stayed on. And yes I did it correctly.
PostSubject: Re: Different day SAME problem   Mon Mar 07, 2011 6:18 am
The mechanics that pay big $ for thier scanners can scan it.
Course, your problem is your immobile
PostSubject: Re: Different day SAME problem   Mon Mar 07, 2011 8:35 am
My buddies $7500 mac super scanner can't do it.You need to have the OBD1 software. I haven't found a garage up here than can do it. And i bought a Can OBD 1and2 scanner, what a POS wouldn't do 1 unless you use 1 of 7 alternate vin codes. Then it might work.
I bought the cable, and got freescan for my laptop, works sometimes. Other times it won't do shit.
PostSubject: Re: Different day SAME problem   Mon Mar 07, 2011 9:45 am
Pickup one of these scanners, works on OBDI. Bought mine 3 years ago and its probably the most useful tool I ever bought.
http://cgi.ebay.com/ebaymotors/Autoxray-EZ-SCAN-3000-OBD-Code-Reader-_W0QQcmdZViewItemQQhashZitem35b06f2383QQitemZ230593340291QQptZMotorsQ5fAutomotiveQ5fTools
PostSubject: Re: Different day SAME problem   Mon Mar 07, 2011 9:55 am
Yup, thats what my neighbor scanned my 93 with. This is its replacement model:
http://www.amazon.com/AutoXray-AX2500-CodeScout/dp/B000IX84KC
Grumpy
PostSubject: Re: Different day SAME problem   Mon Mar 07, 2011 10:48 am
ok I know nothing about your cars problems BUT is there anything you can do to get rid of the opti spark ??? Seems like it's really not dependable at all Surprised These problems that you guys are having would make me sell the car Embarassed
PostSubject: Re: Different day SAME problem   Mon Mar 07, 2011 11:07 am
Some get rid of them, some use the optical sensor only to trigger replacement system.
Many admit, that using properly functioning OEM parts (opti sensor at least), w/ proper installation & when properly sealed they're good for 90-100K
You never hear of someone posting...hey....my OPTI is functioning perfectly
Myself, I'm not smart enough to replace it with something else.
Have 4 LT1's.
#1 replaced opti at like 9oK (guess) & the 2nd one is still kicking at 18XK
#2 no idea when if eever it was replaced, that has 85K & is fine
#3 supposedly replaced in the past 6 months, 185K on car & fine
#4 (the 96) you could eat off, no miles, no problem.
PostSubject: Re: Different day SAME problem   Mon Mar 07, 2011 1:03 pm
I put a used GM opti with low miles on it in my '94 over 10k miles ago. Going strong.
PostSubject: Re: Different day SAME problem   Mon Mar 07, 2011 5:18 pm
Im glad everyones opti is working
PostSubject: Re: Different day SAME problem   Mon Mar 07, 2011 7:37 pm
.. Razz Oops...so....where are we? I forget where we were before you fixed it.
PostSubject: Re: Different day SAME problem   Mon Mar 07, 2011 8:06 pm
It could be worse, it could be an unvented opti in a Camaro.
I took one from a running '94 Camaro and the next day put it in another '94 Camaro and it was dead.
A lot of stuff has to come off just to get at it.
So I put another opti in and this time the wp seal was leaking and I had to do it all over again.
PostSubject: Re: Different day SAME problem   Mon Mar 07, 2011 9:39 pm
The moisture thing has me still thinking opti.
BUT....you changed it & it ran so..
Harness? check pins & continuity, grease it & re-install (swap if an option)
Coil? Hi volt is probably fine, how about the connectors on the coil? loose?
Grounds?
PostSubject: Re: Different day SAME problem   Sun Mar 20, 2011 5:33 pm
I noticed you had the car up for sale again, what happened with the no start issue, did you put another opti in there?
PostSubject: Re: Different day SAME problem   Sun Mar 20, 2011 9:53 pm
Yup. It's on its second new one. I havnt had any problems with the warm weather lately. Tim is coming over tomorrow to take a look and I'm going to change out the cts anyway. If the sale happens, and there's a problem, all I have to do is go and get a new one at advance. So the buyer won't be screwed. Having two b's isn't allowing me to spend any real money on the 9c1. I've spent about 3k in repairs on the 95 not including what I paid for it. That car has more new and custom shit than the 9c1. It's time to go.
