Since I got this car it's been driving me nuts that the map or reading lights whatever you call them, in the rearview don't work,
I assumed blown bulbs, but I finally just found a T7 torx and tried swapping them... NOTHING!
they don't come on when doors are open or when light switch is turned to interior or when switch is pressed.
Only lights inside that work are the under dash ones and the door panel ends. Rear reading lights only work when the switch is pressed.
I checked every fuse (I believe) any thing else I'm missing? Connection is good on mirror and I even unplugged and swapped in a known good mirror. Still a no go,
I read old posts here and I don't believe it's a door jamb switch.
