» Looking for SEO 6J6 wiring [FOUND]
Bizarre roadmaster electrical issue EmptyWed Aug 21, 2019 4:28 pm by MASShole9C1
Bizarre roadmaster electrical issue EmptyThu Aug 08, 2019 9:41 am by CrashMaster
» 1984 Caprice project
Bizarre roadmaster electrical issue EmptySun Jun 30, 2019 8:05 pm by Boxchevy84
» C10: Before and After
Bizarre roadmaster electrical issue EmptySun Jun 02, 2019 3:01 pm by MalibuSSwagon
Bizarre roadmaster electrical issue EmptySat Mar 16, 2019 8:49 am by boojum
» Mass refugee now in Pa
Bizarre roadmaster electrical issue EmptyTue Jan 22, 2019 8:46 am by MASShole9C1
Bizarre roadmaster electrical issue EmptyTue Jan 22, 2019 12:03 am by boojum
» 1996 DGM RMW
Bizarre roadmaster electrical issue EmptyFri Jan 18, 2019 12:00 pm by Gorillabiter
August 2019
Share
PostSubject: Bizarre roadmaster electrical issue   Bizarre roadmaster electrical issue EmptySat Nov 17, 2012 6:21 pm
So I've been having this issue with the wagon for like 3 weeks now. I THOUGHT I knew what it was but I replaced that and it's still doing it,
Here's the symptom:
While driving every so often mostly over bumps the speedo needle bounces/ jumps, the ABS-low gas-check engine-oil or any combination of warning lights flash and the radio makes a "thump" through the speakers.
What I thought it was:
Power distribution box inside engine compartment was held together with duct tape and the main 8 gauge power wire was wrapped up like a mummy in electrical tape.
When I took it apart I replaced the stud AND the metal holders for the main body fuses. I did notice the other two wires coming off the side looked a little burned, but I assume it's from the stud arcing.
I filed and wire brushed all connections. So maybe it wasn't this? Maybe the burned wires need new crimps?
Am I barking up the wrong tree?
Does it sound like a ground problem?
Also noticed since installing the electronic flasher that the speedo needle ticks a little with the flashing... Related or just something that happens?
Oh and when the main "problem" happens at night with headlights on I notice some slight dimming on and off with the headlights.
PostSubject: Re: Bizarre roadmaster electrical issue   Bizarre roadmaster electrical issue EmptySat Nov 17, 2012 7:29 pm
You have bad ground(s) somewhere.
Bizarre roadmaster electrical issue ToastedSig_zps6c195980
PostSubject: Re: Bizarre roadmaster electrical issue   Bizarre roadmaster electrical issue EmptySat Nov 17, 2012 7:50 pm
Any particular one I should start start on? Coil? Head ground strap? Or aomthing specific on that circuit?
I did notice the aftermarket radio ground wire was a little loose in the harness (cd player side) you think that could cause mayhem in the whole car? Or it's just a coincidence?
PostSubject: Re: Bizarre roadmaster electrical issue   Bizarre roadmaster electrical issue EmptySat Nov 17, 2012 10:59 pm
Take a look at some ground distribution charts to try and track it down.
PostSubject: Re: Bizarre roadmaster electrical issue   Bizarre roadmaster electrical issue EmptySat Nov 17, 2012 11:06 pm
I actually just talked the original owner of the car (and I mean the guy I bought it from bought it new so ORIGINAL!)
and he said that distribution block was causing the lights to flicker and the car would also just die.
But I'm still for the ground idea. I know I've done a ton to modify the car, but by him saying he had the problem too shows it's nothing I did directly to cause the problem. I'm planning to go forward with the FWB front clip like I originally wanted once I start cutting up the black car. When I do that I plan to replace the entire engine harness with the one from the dggm car. but for now I'll do some snooping in the usual places.
PostSubject: Re: Bizarre roadmaster electrical issue   Bizarre roadmaster electrical issue EmptySun Nov 18, 2012 7:35 am
Auxiliary Battery Post
PostSubject: Re: Bizarre roadmaster electrical issue   Bizarre roadmaster electrical issue EmptySun Nov 18, 2012 8:24 am
He said he already replaced that though. I thought the same thing at first.
PostSubject: Re: Bizarre roadmaster electrical issue   Bizarre roadmaster electrical issue EmptySun Nov 18, 2012 9:37 am
Yeah but there were 2 wires coming off the side that were green with corrosion and looked severly burned, I only wire brushed them. There could be damage to the wires that I didn't see. It's very tight there. I'm gonna cut the wires Today and replace the connectors.
PostSubject: Re: Bizarre roadmaster electrical issue   Bizarre roadmaster electrical issue EmptySun Nov 18, 2012 1:17 pm
Good call Tom. Make sure the nut is tight on that aux post. The nut on my Caprice was loose and it kept going dead while driving down the street. Drove me absolutely crazy one night. I even had it towed and put a new battery in it for nothing.
PostSubject: Re: Bizarre roadmaster electrical issue   Bizarre roadmaster electrical issue EmptySun Nov 18, 2012 3:40 pm
No definitely NOT that auxiliary post that was what I did before writing out the thread. I replaced everything there.
Just replaced a broken head to firewall groud strap and also found the fender to battery ground had melted the coolant bucket and was loose.
So far no issues, so I'm pretty sure the ground was the issue.
Thank you Bill, Tom, and Tim for the ideas/help!
PostSubject: Re: Bizarre roadmaster electrical issue   Bizarre roadmaster electrical issue EmptySun Nov 18, 2012 4:52 pm
Do the LT1's have a T-stat ground like the TBI's?
PostSubject: Re: Bizarre roadmaster electrical issue   Bizarre roadmaster electrical issue EmptySun Nov 18, 2012 4:57 pm
No, they are all on the coil bolt I beleve.
PostSubject: Re: Bizarre roadmaster electrical issue   Bizarre roadmaster electrical issue EmptySun Nov 18, 2012 5:51 pm
Sounds like you found it, but if you run into it again check the grounds inside the car. There's a ground point behind the kick panels on both sides of the car, might need to pull the sill plate off to see them.
PostSubject: Re: Bizarre roadmaster electrical issue   Bizarre roadmaster electrical issue EmptySun Nov 18, 2012 6:58 pm
Missed that you replaced the auxiliary post, I've had grounds cause strange problems. Glad you figured it out.
PostSubject: Re: Bizarre roadmaster electrical issue   Bizarre roadmaster electrical issue EmptySun Nov 18, 2012 7:32 pm
This thread makes me realize I have a LOT to learn about the LT1 cars coming from the TBI ones...lol.
Glad you found it, I'll wait until I have the other stuff sorted out but I think I'll remove/clean all the grounds on the SS (carefully) when I get a chance... Smile
» Bizarre roadmaster electrical issue
» Wanted: centers for Roadmaster wheels / front turn signal lens
» 1995 buick roadmaster
» buick roadmaster
» What's the best factory radio to install in the Roadmaster?
