| | Roadmaster int. lights stuck on? | |
| Subject: Roadmaster int. lights stuck on? Mon May 17, 2010 8:37 pm | |
| Just had to help my brother with his car- The prev. owner installed a system in the car and grounded the amp to where there is a ground wire from the factory (I think) in the trunk on the driver's side near the hinge. Well this connection was ultra-ghetto, it kept falling off and the wire was all mashed around a machine screw to hold it on. I got a bolt, nut, lock washer and crimped an eye on the end of the wire to keep it on for now, seems fine. Anyway, the main problem is BOTH wires fell off when he was driving back from Lowes. Oddly enough I was in the car when this happened- it began to run sluggish, power locks acted up, lights were dim, the turn signals wouldn't flash, when the brakes or turn signals were put on the car would almost stall, etc. Got the car home thank god, there was a VERY slight burning smell someplace from the car, I disconnected the battery right away and I fixed the ground correctly, let it sit for a bit, now the car runs and drives fine and most things work too, BUT the interior lights won't shut off! There is a fuse for the interior light dimmer, it didn't look blown but I don't have my multi-meter to test it. I pulled the power lock/inter. light fuse, which was also good, just so the battery won't die. Any ideas, maybe some wire got burned? I'm bad with this stuff but maybe there's some telltale sign of what the car is doing to what might have gone bad? I'll have a better idea when I can check all the fuses with the DM but figured I'd ask you guys... | |
| | | Matt Trakker
| Subject: Re: Roadmaster int. lights stuck on? Tue May 18, 2010 12:05 am | |
| http://www.impalassforum.com/vBulletin/showthread.php?t=242604&highlight=interior+lights
Just saw that...sounds plausible | |
| | | bammax
| Subject: Re: Roadmaster int. lights stuck on? Tue May 18, 2010 4:27 pm | |
| When mine had that issue I went in this order:
door jam switch dimmer switch timer box
In my case it ended up coming back to the door jam switch not being fully tightened which led to it not fully depressing. | |
| | | RoadmonstahRed94
Posts : 5 Join date : 2010-10-16 Location : Malden, MA
| Subject: Re: Roadmaster int. lights stuck on? Mon Nov 22, 2010 7:08 pm | |
| Hey guys Matt and I messed around with the car tonight, he pulled out some green box thing under the dash by the brake pedal, and the white twilight sentinel box that's behind the pass side kick panel, and the dome lights STILL stay on...lol
Any ideas? I guess it could be either the headlight switch or the door jam switches? The reason I'm worried is because this all happened when a ground wire fell off inside my truck and the whole car went haywire...I hope nothings shorted out | |
| Subject: Re: Roadmaster int. lights stuck on? Mon Nov 22, 2010 7:51 pm | |
| Well, I'd start by pulling the door jamb switches one by one now, see if it goes out. Hopefully a wire didn't burn out somewhere along the way... | |
| | | Matt Trakker
| Subject: Re: Roadmaster int. lights stuck on? Mon Nov 22, 2010 8:40 pm | |
| I'll try to help him out with that next. Like he said, I took out the green box up under the dash, opened it up, didn't see any bad contacts inside...put the fuse back in, same problem. Left it out and did the same with the white T.S. control box behind the kick panel, and they were still on. The headlight switch has that copper tang inside that's visible with the fuse box door off, and that loses contact with the other metal piece when you "shut off the dome lights" as well, so I don't think that's the issue, maybe something IN the switch can crap out?
| Subject: Re: Roadmaster int. lights stuck on? | |
