Marshmallow drop... EmptyWed Oct 19, 2022 1:27 pm by scot
Marshmallow drop... EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Marshmallow drop... EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Marshmallow drop... EmptyFri Sep 24, 2021 9:53 am by ElKy
Marshmallow drop... EmptySun Sep 19, 2021 6:22 pm by black blur 96
Marshmallow drop... EmptySun Jun 20, 2021 11:37 am by scot
Marshmallow drop... EmptyFri Jun 11, 2021 10:41 am by scot
Marshmallow drop... EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Marshmallow drop... EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 Marshmallow drop...
8 posters
PostSubject: Marshmallow drop...   Marshmallow drop... EmptySun Apr 19, 2009 8:53 pm
As mentioned in the other thread, I finished up on the lowering of the Marshmallow today. Thanks to Doug and Anthony, the Vogtlands got installed yesterday with the stock isolators. Tim gave me a hand with the front shocks. I used Gabriel HD 9C1 package shocks up front. In the rear, I decided to keep the stock air shocks for now, as they were still holding air. Here's the low low...
First, I popped the stock adjuster arm off the auto-level sensor for the rear air ride. Then I hit a hobby shop and got the biggest turnbuckle ends I could find.
Marshmallow drop... MarshmallowDrop002Medium
Then I threaded the ends on and made it about 1/4" shorter than the stock one.
Marshmallow drop... MarshmallowDrop007Medium
The ends weren't quite big enough, so I snipped them at then ends so they could open a lil. Turns out they opened a LOT. Oops. Hopefully it'll stick together this week until I can come up with something else. The factory one had a broken end, so I can't use threaded rod with the stock ends. I think. I'll see what I can figure out with that. I still need to shorten it some anyways, because when I took it off the stands, the compressor actually kicked on and raised it some.
Next, I installed my Addco rear bar. It installs by securing a plate to the LCA and then mounting the bar to the plate. There are 3/4" or so round spacers on the bolts between the arms to keep them from collapsing when tightened. I actually had to so some drilling, to to get them mounted. Luckily, there was a set of holes in the front of the arm (towards the nose of the car) already, which I only had to open up to 3/8" with a drill. For the rear holes, there was already a 3/8" hole in the right place, but there wasn't one opposite it, so I had to drill those completely. No biggie! My 1973 Crapman was up to the task! Here's a few shots of the bar...
Marshmallow drop... MarshmallowDrop008Medium
Marshmallow drop... MarshmallowDrop009Medium
Marshmallow drop... MarshmallowDrop010Medium
When I put it down off the stands, it measured 27 1/4" to the front lip from the ground and 20 5/8" to the rear skirt. I didn't measure it after the test drive, because I didn't pull it back onto the level concrete, but it did drop some more in the 5 mile or so test drive. Smile Here are the lowered pics:
Marshmallow drop... MarshmallowDrop011Medium
Marshmallow drop... MarshmallowDrop012Medium
Marshmallow drop... MarshmallowDrop013Medium
Marshmallow drop... MarshmallowDrop016Medium
Marshmallow drop... MarshmallowDrop018Medium
Marshmallow drop... MarshmallowDrop019Medium
I think it looks just about perfect! The rear needs to come down another inch or so, and I think that once I figure out what I need to do with the adjuster rod, I can get it where I want it.
How'd it ride? NICE! Not near as firm as the SS, with the Hotchkis and Bilsteins, but firmed up a lot. And that rear bar? Wow! No more roll! I didn't push it at all or anything, but it is noticeable even at the 30-40MPH I was doing on my test loop. Smile Very happy. Thanks to all that helped with the install! I am really happy with the way it turned out.
I still plan to install the rear Gabriel HD shocks and put Airlift bags in the coils hooked into the stock auto-level though. That will be the cat's bananas. Or something. Wink
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptySun Apr 19, 2009 9:17 pm
Looks like it has a sick rake, which is probably due to the leveling system. The front stance is awesome.
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptySun Apr 19, 2009 11:15 pm
cant wait to see it when the springs settle completely
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptyMon Apr 20, 2009 5:56 am
the front sits perfect.
the back, umm not so much. Razz
but you already know that.
good luck on the auto level fix.
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptyMon Apr 20, 2009 6:52 am
Looks kick ass Bill. cheers
The wheels without the caps look cool too. Wink
I think the stance looks good too.
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptySun May 03, 2009 9:52 am
so what the news on the auto level fix?
did you get it to sit more level?
inquiring minds want to know.... Very Happy
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptySun May 03, 2009 4:29 pm
I have a shorter linkage made up, and it's "adjustable" but I haven't installed it yet. It'll work though. Smile
I used the stock ends and some threaded 10/24 rod and some Gorilla glue. Smile It's ugly. But it should work!
Bobby came over today and gave me a hand installing my hood, too. She's coming along! Thanks again Bobby! Very Happy
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptySun May 03, 2009 4:52 pm
How did you paint the hood?
All white? Did you leave the intake holes black?
Pics please!
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptySun May 03, 2009 5:07 pm
Pics please!
I did what I thought was the smart thing and had a body shop paint it. Boy, what a friggin mistake THAT was! Wrong color. Runs. Looks like ASS!!!! And he had it TWO WEEKS!!!! Grrrrr...
I shoulda stuck with my instinct and sprayed it myself. For CHEAPER! Evil or Very Mad
I'll snap some pics in a few. I'm watchin the baby right now. Smile
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptySun May 03, 2009 5:37 pm
OK, so here's a couple pics. I will probably black out the "nostrils" at some point. But I'm kinda diggin the all white. We'll see. Anyways....
Fancy new grille that still looks chrome! Thanks Timmah!
Marshmallow drop... BuickInDaHood002Medium
The "looks ok, but really needs to come down a 1/2" @ the hinge" shot...
Marshmallow drop... BuickInDaHood003Medium
The "I'm a playah cuz I takes picz like this, yo!" shot...
Marshmallow drop... BuickInDaHood004Medium
Yes. I know. I'm lazy. Jr can clean them. Wink
Marshmallow drop... BuickInDaHood006Medium
The "Ok asshoal, what's wrong with a stock hood" shot...
Marshmallow drop... BuickInDaHood007Medium
I also pulled all the black rubber trim and spent about 2 hours with a razor blade (like 40 actually) and goo gone, then 2 hours with chrome polish and steel wool over the period of about a week. I think it looks good. It better. Cuz it's stayin that way!
Marshmallow drop... BuickInDaHood008Medium
Marshmallow drop... BuickInDaHood009Medium
It'll look really good if I can squeeze the chrome rims on there that I want to! Smile
So... She's coming along.... Slowly but surely. (Yes. I am serious. Very Happy)
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptySun May 03, 2009 5:47 pm
hood looks great. Cool
nice work on the rubber trim removal. cheers
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptySun May 03, 2009 7:21 pm
paint the nostrils black!
Nice grill! Very Happy
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptySun May 03, 2009 8:53 pm
Lookin' NIce jocolor
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptySun May 03, 2009 10:31 pm
I like it. But it is missing something. scratch
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptyMon May 04, 2009 12:38 am
I guess you got the hood on. Smile
Buy a can of flat black. Don't use that satin stuff!
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptyMon May 04, 2009 8:36 am
TINT! Hopefully this week. afro
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptyMon May 04, 2009 8:46 am
No. I mean the hood. I think IMO it needs some buick GS hood stripes. Shocked
Marshmallow drop... 6dd0_12
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptyMon May 04, 2009 9:11 am
I dunno. Maybe. I think the "dome" would look pretty cool blacked out, too. But I don't think I want any stripes or anything on this car. We'll see. Smile
UberWagon
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptyMon May 04, 2009 12:18 pm
White corners!
If you are not going to put the rubber strips back on you could always sand that area with some 180/200 grit for a brushed look. I did that to one side of my car (between crappy weather and hectic military scheduling I have yet to finish the other side) with the intention of spraying it with satin black and I liked the contrast so much that I left it like that.
FUN-9C1
FUN-9C1
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptyMon May 11, 2009 12:38 am
Looks awesome, Bill, nice work! You are one bad modification MoFo!!
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptyMon May 11, 2009 8:17 am
Thanks Rob! Smile
We gonna see you at the drag day?
FUN-9C1
FUN-9C1
PostSubject: Re: Marshmallow drop...   Marshmallow drop... EmptyMon May 11, 2009 12:21 pm
That is a definite maybe! I still need to install the radiator which I will get tomorrow (no big deal) and get a new windshield. I need to get off my ass and make an appointment for the windshield as I'm not sure how long the waiting period is. Then I need to convince Kim that spending a day at the drags is a wise investment of time and money that we have neither of! But I suppose I really SHOULD get in some practice before I go there for "Westinghouse Drag Day".... Laughing Seriously, though, maybe since there's very little interest here at work for a drag day, the few of us that are interested could go the same day as this one, and I could combine the two if I'm done in time... hmmm.....
Marshmallow drop...
» Still had a little fun in the Marshmallow...
» Craigslist finds
» Roadmaster ZEEEEEE Cluster in the Marshmallow! :)
» Marshmallow feeler...
» Marshmallow Fluffed...
