Roadmaster ZEEEEEE Cluster in the Marshmallow! :) EmptyWed Oct 19, 2022 1:27 pm by scot
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) EmptyFri Sep 24, 2021 9:53 am by ElKy
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) EmptySun Sep 19, 2021 6:22 pm by black blur 96
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) EmptySun Jun 20, 2021 11:37 am by scot
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) EmptyFri Jun 11, 2021 10:41 am by scot
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
2 posters
PostSubject: Roadmaster ZEEEEEE Cluster in the Marshmallow! :)   Roadmaster ZEEEEEE Cluster in the Marshmallow! :) EmptyFri May 15, 2009 10:09 pm
I finally got around to installing Gary's Roadmaster/Z28 cluster today!!!! Woot! Smile I'm pretty happy with my install, and it looks killer with the woodgrain! There is still something I need to address with my install though...The cluster moves/floats a bit in its new bracket, and I am not completely happy with the way it is sitting in its bracket at present. It's totally my fault, as I didn't notice it until I had it all buttoned up. I need to take it back out when my green LED's show up anyways, so I'll straighten it out then. Smile
So anyways here's a quick little run through of my install...
I started by removing my cluster. Nice and easy! You take off the two bolts off above the cluster and then the whole dash face (from door to door) just pulls off. Remove the four 7mm screws on the cluster, give it a tug, unclip the PRNDL wire from the column, and you have this:
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) Cluster028Medium
Then you pop the sockets for the cluster out of their homes so you can move them to install the new cluster:
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) Cluster029Medium
Not much trimming is needed. I spent about 10 minutes with a dremel. Gary included a template. I put it in place and marked it with a Sharpie and then cut. Be careful when you trim! There is a wiring harness underneath a couple places you cut!:
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) Cluster030Medium
I marked and cut, but it didn't seem to fit quite right yet, so I trimmed a little more:
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) Cluster034Medium
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) Cluster035Medium
Another trial fit. Looked good, so just secure it with the same screws you took out of the stocker. Be careful when you are tightening it down the final time, making sure that the speedo and tach needles aren't stuck under the bracket. (Ask me how I know):
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) Cluster031Medium
Looks good! So I then put the dash face back on and snapped a few more pics:
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) Cluster046Medium
And in these pics you can see how nice the wood matches!
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) Cluster042Medium
Roadmaster ZEEEEEE Cluster in the Marshmallow! :) Cluster043Medium
I then went under the hood and made the tach connection. Pretty straightforward. Run the included wire to the PCM. Plug it into the red plug, spot 13. I didn't think to take any pics of it though. Sorry! Then all you have to do is swap out the oil pressure sender at the back of the intake, under the EGR. I used one from a 95 Z28. Screwed right into place! Do yourself a favor and grab an "oil pressure sender socket" at Autozone for 10 bucks and make your life a million times easier. Smile
So with those connections made, I was done! I HAVE GAUGES!!!!! Looks factory. No, looks AWESOME! Works great! I'm happy!!!! I'll be even happier when I adjust it a little in the bracket and install my LED's. All in all, it took about an hour to install.
You ABSOLUTELY need one of these!
Thanks Gary!!!! Very Happy
PostSubject: roadmaster zeeeeee cluster in the marshmallow   Roadmaster ZEEEEEE Cluster in the Marshmallow! :) EmptyFri May 15, 2009 10:36 pm
bill its about time. ive been waiting for almost a week now. looks nice. i went out and bought the oil pressure switch already. thanks for the info for socket.do you have a part number? makes it easy for us lay men. my list of things to do. have billymac do my seats. have mikeod tranny and tweaks. hids. z28 clusters.my new aluminum heads sent to adi. but this all depends on my income like ever body else.just remember to have your wifes (parteners)buy land o lakes products. thats my profit sharing.ive another check coming in june.
» Marshmallow Fluffed...
» Still had a little fun in the Marshmallow...
» Marshmallow feeler...
» Marshmallow drop...
» Let me reintroduce to you, The Marshmallow!!!!
