A/C fan question EmptyWed Oct 19, 2022 1:27 pm by scot
A/C fan question EmptyTue Oct 18, 2022 8:58 pm by silverfox103
A/C fan question EmptyTue Sep 28, 2021 11:01 pm by silverfox103
A/C fan question EmptyFri Sep 24, 2021 9:53 am by ElKy
A/C fan question EmptySun Sep 19, 2021 6:22 pm by black blur 96
A/C fan question EmptySun Jun 20, 2021 11:37 am by scot
A/C fan question EmptyFri Jun 11, 2021 10:41 am by scot
A/C fan question EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
A/C fan question EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 A/C fan question
2 posters
MancheSSterJake
MancheSSterJake
PostSubject: A/C fan question   A/C fan question EmptyThu Jul 18, 2013 10:47 am
I am trying to figure out if the axillary fan is supposed to come on when the A/C is on. My mechanic buddy tells me that it should but I dont believe so. He had the A/C gauges hook up and jumped the fan to come on. The upper pressures dropped when the second fan came on.
So my question is: Does anyone have both fans come on when the A/C is on Max? Or do I just get the smaller primary fan?
I know the second fan is set to come on when the engine temp gets to a certain point.
Thanks!
PostSubject: Re: A/C fan question   A/C fan question EmptySat Jul 20, 2013 3:16 pm
Ok, I just checked for you.
My AC on max, engine running, BOTH fans are on.
MancheSSterJake
MancheSSterJake
PostSubject: Re: A/C fan question   A/C fan question EmptySat Jul 20, 2013 4:35 pm
The problem is that on the National forum they are saying that the second fan is only supposed to come on when the upper pressure in the A/C system hits a certain point.
The factory manual is hard to understand when it comes to the second fan, but it seems to confirm that the second fan should not come on until a certain point.
With a cold motor just started and the A/C switched to Max the system should not be built yet to high pressure yet. So that would indicate that the second fan would not be on.
So what I would need to know if the second fan is on with the engine just started.
PostSubject: Re: A/C fan question   A/C fan question EmptySat Jul 20, 2013 4:49 pm
Ok, what I've got is a semi warned up engine.
I just started it with AC on max.
Both fans on.
I turned AC off and the drivers side fan slowed to a stop.
FWI there's no "smaller fan". They're the same size and because of that, one is canted lower.
MancheSSterJake
MancheSSterJake
PostSubject: Re: A/C fan question   A/C fan question EmptySat Jul 20, 2013 9:30 pm
I have a very original 95 Impala SS. The fans are different sizes. V03 option code. The primary fan on the passenger side is smaller. This is correct.
PostSubject: Re: A/C fan question   A/C fan question EmptySat Jul 20, 2013 9:37 pm
Strange... I have VO3 too.
Not sure what very original has to do with it. I rarely see anyone install aftermarket fans if that's what you mean.
MancheSSterJake
MancheSSterJake
PostSubject: Re: A/C fan question   A/C fan question EmptySat Jul 20, 2013 9:50 pm
According to my factory manuals the fans are two different sizes on the V03.
I see yours is a Caprice police. They may have had different fans.
PostSubject: Re: A/C fan question   A/C fan question EmptySat Jul 20, 2013 10:00 pm
My FSM says your FSM is full of shit.
The only difference is motors. VO3 cars had a 150w and 240w respectively for the 2 fans.
Base models were 150w and 100w.
VO8 is 1 electric fan, one mechanical.
I think you're confused by the fan on the passenger side mounted lower in front of the AC pump.
Looks smaller.
MancheSSterJake
MancheSSterJake
PostSubject: Re: A/C fan question   A/C fan question EmptySat Jul 20, 2013 10:10 pm
Perhaps I did not use the correct terminology. What I was referring to was the motors size, no the physical size.
PostSubject: Re: A/C fan question   A/C fan question EmptySat Jul 20, 2013 10:14 pm
Aha! There it is.
In that case, then you are correct, just as the FSM states the differences for the various RPO codes.
A/C fan question
» Got a question for ya'll.
» PSI question
» 93 RMS Question
» Q-jet question
» 4L60E Question
