 PSI question
PostSubject: PSI question   Sat Apr 27, 2013 8:11 pm
The 17" hankooks I have say max PSI is 50.
Now, given that the tires are wider (even wider in the rear), but not taller, than a stock 9C1 size tire, what is the BEST PSI for this situation?
They look pretty under inflated to me but I don't want to over inflate and trash the treads on the highway.
PostSubject: Re: PSI question   Sat Apr 27, 2013 8:17 pm
I usually run 35 psi in my cars. Keep an eye on the wear pattern. If they wear in the middle, lower your pressures. If they wear on the outsides, add a couple psi.
PostSubject: Re: PSI question   Sat Apr 27, 2013 10:20 pm
I'm NEVER over 35
I like 32
PostSubject: Re: PSI question   Sun Apr 28, 2013 12:20 am
what size tires?
tire pressure depends on how you drive the car,.how tall the sidewalls are,. how much weight you're carrying,.
a tall tire will squirm under hard cornering,.
an underinflated tire runs hot,.and deflects a lot when you hit an obstacle (pothole)
tall underinflated tires break belts,. separate belts etc,..
underinflated tires use more fuel,.
underinflated tires may wear evenly,. but they will wear faster,.
on any of my 255-50-17's i run them at 40 psi minimum,.
60psi when i,m flogging the tires on a road course,.
the minivan tires are 215-65-16,.i run them at 38,.
the fancy ford has 225-60-16's,..i run them at 40.
I run my 11X24.5's at 105.
Nick
yrmv
nweoi
pdcc
PostSubject: Re: PSI question   Sun Apr 28, 2013 12:30 am
Thanks guys. I'm not sure 35psi is what I'm looking for here.
Nick, I'm running 245/45ZR17 (17x8 rim) front And 275/40ZR17 (17x9 rim) rear.
PSI question
» Dark Fusion / Mirror Force question
» Question on scrap dragon
» Ginkgo Question
