So I went and looked at a 93 RoadMaster Sedan. L05 car.. Will be a winter beater if I pick it, but a CLEAN winter beater.. Anywho, It wont start. Cranks, but doesnt start. I was checking the fuses in the fuse panel on the drivers side of the dash. The ECM fuse doesnt light up when I test it with a Test Light. All the other fuses DO work(light up my test light, aside from Heated Mirrors, thats a no go). I have the ignition ON but car not running while Im testing the fuses. The Fuse isnt blown either? I just cant get the test light to light up at either post on the fuse. I swapped fuses too, still nothing. Is it Supposed to be this way? What would cause this? Thanks guys -Paul
