| plastic heater hose tee | |
soshoresig
Posts : 34 Join date : 2010-09-13
 | Subject: plastic heater hose tee Thu Oct 06, 2011 3:47 pm | |
| Ok, so I got her runnin' and then it blows anti-freeze everywhere. Where can I get the plastic tee with crimped on hose that goes between the heater hoses and the overflow bottle??? tried local and rock auto no dice |
Posts : 4253 Join date : 2009-12-16
 | Subject: Re: plastic heater hose tee Thu Oct 06, 2011 4:04 pm | |
| Pm me a picture of what you need and I can check the yard. What exactly is leaking? What year? Caprice or impala SS ? |
soshoresig
 | Subject: plastic tee Thu Oct 06, 2011 6:09 pm | |
| Its a 96 Impala SS and its a Grey plastic tee with one end connected to heater hose to the fire wall, the other end connected to hose going to heater hose to intake, and the bottom of the tee has a hose permently crimped on to it that attaches to the bottom of the coolant overflow bottle. Ill try to get you a picture of it tomorrow. Thanks |
 | Subject: Re: plastic heater hose tee Thu Oct 06, 2011 6:14 pm | |
| Ok. Pics are the best so I know how much of it to get if I find it. We've got a few relatively untouched wagons and and a roadie that just showed up. |
Posts : 372 Join date : 2011-02-03 Age : 42 Location : brockton
 | Subject: Re: plastic heater hose tee Thu Oct 06, 2011 6:38 pm | |
| its GM part # 10258504 delco # 15-5508. Costs about $66. Comes crimped with hoses. |
 | Subject: Re: plastic heater hose tee Thu Oct 06, 2011 6:42 pm | |
| What mike has there might be better. Not too expensive if you want new. I'd go that route myself. |
Posts : 2132 Join date : 2011-01-11 Age : 36 Location : Warren, MA
 | Subject: Re: plastic heater hose tee Thu Oct 06, 2011 7:38 pm | |
| I might have one left over from the dggm b4u caprice. It only had 53k miles on it. I'll look tomorrow in the bins of parts. |
Posts : 1506 Join date : 2009-01-25 Age : 23 Location : Littleton, NH & St. Simons Island, GA
 | Subject: Re: plastic heater hose tee Thu Oct 06, 2011 7:59 pm | |
| Less expensive alternative:
1. GM "T" #12522867, $12
2. Hose from overflow tank to heater hose: NAPA #11625--$10
I have used this setup twice, works great.
Tom |
soshoresig
 | Subject: Re: plastic heater hose tee Sat Oct 08, 2011 6:00 am | |
| Thanks Tom, I'll give that I try. |
Posts : 1433 Join date : 2009-11-10 Age : 33 Location : Connecticut
 | Subject: Re: plastic heater hose tee Sun Oct 09, 2011 11:50 pm | |
| Just did this over the weekend on my RMW. I replaced it wth brass plumbing parts, cost about $30, but will outlast the car. Pickup a 3/4" brass T, 2x 3/4" - 3/4" barb fittings, and 1x 3/4" - 5/8" barb fitting. |
soshoresig
 | Subject: Re: plastic heater hose tee Fri Oct 14, 2011 9:19 pm | |
| thanks Tom, did this: Less expensive alternative:
worked awesome! |
 | Subject: Re: plastic heater hose tee Fri Oct 14, 2011 10:15 pm | |
 | Subject: Re: plastic heater hose tee  | |
