| Plastic Fuel Tank | |
| Subject: Plastic Fuel Tank Mon Sep 30, 2013 11:27 pm | |
| I thought I had this covered, but I realized the yard I snagged it from was kind enough to blast a giant hole through it Could one of you fine gents be kind enough to hook a brother up with a 91-96 plastic fuel tank (sending unit/ and hanger would be a huge plus! Let me know asap!! | |
cmccabe
Posts : 101 Join date : 2009-04-01 Age : 50 Location : Concord, NH
| Subject: Re: Plastic Fuel Tank Tue Oct 01, 2013 6:16 am | |
| I have one in my 93 Roadmaster sedan. | |
| Subject: Re: Plastic Fuel Tank Tue Oct 01, 2013 8:11 am | |
| Only wagon tanks over here | |
| Subject: Re: Plastic Fuel Tank Tue Oct 01, 2013 7:16 pm | |
| - cmccabe wrote:
- I have one in my 93 Roadmaster sedan.
How much? | |
cmccabe
| Subject: Re: Plastic Fuel Tank Wed Oct 02, 2013 10:02 am | |
| $40.00 sound fair?
Let me know
603-491-5550 | |
| Subject: Re: Plastic Fuel Tank Wed Oct 02, 2013 4:46 pm | |
| - cmccabe wrote:
- $40.00 sound fair?
Let me know
603-491-5550 Sounds very fair...but just realized you are in NH (quite the hike for me). If i get in a bind on the local hunt, I will take it...but I am going to look a little harder here first. | |
cmccabe
| Subject: Re: Plastic Fuel Tank Wed Oct 02, 2013 7:45 pm | |
| well it turns out the scrap guy decided to "help me out and come a day early. Its gone. I am very sorry. | |
IMPALADAKID Admin
| Subject: Re: Plastic Fuel Tank Wed Oct 02, 2013 8:25 pm | |
| Any sedan 91-96 share the same tank. I am sure the same sending unit. Not sure about that or if the pump is the same or not. But You should replace the pump with a new AC Delco unit since you have the tank out anyways. | |
| Subject: Re: Plastic Fuel Tank Thu Oct 03, 2013 8:22 am | |
| I have a tank, but I'm not sure I wanna sell it. All tanks 91-96 for sedans are the same. All sending units are the same, some came with cups around the pump to prevent fuel starving, 91-93 pumps are made for 12psi 94-96 pumps are made for 41psi
Neither one matters since the ls1 needs 58psi of fuel pressure.
Any chance you have obd1 tuning software? I still need all the crap turned off in my PCM for the lt1 swap truck. | |
| Subject: Re: Plastic Fuel Tank Thu Oct 03, 2013 10:22 am | |
| - Ironfistdog wrote:
- Any chance you have obd1 tuning software?
I still need all the crap turned off in my PCM for the lt1 swap truck. Is that the chippable PCM? You should be able to use tunerpro on it. | |
| Subject: Re: Plastic Fuel Tank | |
