» Anybody out there?
Front frame brace from Pro-Touring F-body EmptyWed May 01, 2024 10:41 am by BostonChevy
Front frame brace from Pro-Touring F-body EmptyWed Oct 19, 2022 1:27 pm by scot
Front frame brace from Pro-Touring F-body EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Front frame brace from Pro-Touring F-body EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Front frame brace from Pro-Touring F-body EmptyFri Sep 24, 2021 9:53 am by ElKy
Front frame brace from Pro-Touring F-body EmptySun Sep 19, 2021 6:22 pm by black blur 96
Front frame brace from Pro-Touring F-body EmptySun Jun 20, 2021 11:37 am by scot
Front frame brace from Pro-Touring F-body EmptyFri Jun 11, 2021 10:41 am by scot
Front frame brace from Pro-Touring F-body EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
May 2024
2 posters
scot
PostSubject: Front frame brace from Pro-Touring F-body   Front frame brace from Pro-Touring F-body EmptySun Aug 28, 2016 12:38 pm
A long time ago prior to building the S/C T-56 Brembo Brake $$$ export cars; I exchanged an 94 Impala SS frame for one from Progressive Automotive,a radically more rigid frame in every plane. The car rode better and handling improved a little. Seemed counter intuitive, but it wasn't. The more rigid frame leveraged the suspension with less frame flex, so it felt a little more precise in handling and it rode better because the whole car was more tied down. Flash forward and Install the Pro-Touring Sway Bar Brace and something similar happens in front. It took energy to flex the front frame rails without the brace, which effectively was like having a smaller, less stiff sway bar. If some bar stiffness (roll resistance) is used to bend the frame, it's not available for roll resistance. Adding the brace makes the frame more rigid so the previously wasted energy now is like making the suspension stiffer. So the frame being stiffer does not make the car ride harsher; it's the now more effective front sway bay, as if you increased the diameter/spring rate of the bar, making the suspension stiffer. That's what you feel. Take off anything that makes the frame more rigid and you'll perceive a softer ride but that's because you're back to diminishing the efficacy of the sway bars and springs, making the suspension feel less stiff. An infinitely (impossible at least today) rigid frame with no frame spring rate (flex) would ride better with a set up for equal handling to a weak frame car because you could use softer springs and sways to get equal handling now that you're not wasting suspension energy bending the weak frame.
PostSubject: Re: Front frame brace from Pro-Touring F-body   Front frame brace from Pro-Touring F-body EmptySun Aug 28, 2016 2:43 pm
Interesting post,. right out of the blue,.
A really good set of shocks set on stun on the extension side,. and gentle on the compression side work wonders for ride and handling too,.
I really like the weld in rear brace,. cheap and nasty but really effective,.,. which appeals to me
Similar to 4 lengths of 5/16th preloaded chain added at the track for a little stock appearing track time,?. Wink
» Do B body and D body front fender wells interchange?
» 1996 TBI Vortec-headed 350s in the old body style Chevy vans, potential B-body swap?
» wagon body off frame?
» Nov. 17th AKA Body on frame day. Seeking club help!
» 2nd Gen F Body Front Sway Bars
