| | Cheapest way to remove VATS. EGR, AIR, o2's. from obd2 pcm | |
| Subject: Cheapest way to remove VATS. EGR, AIR, o2's. from obd2 pcm Sun Jul 21, 2013 5:37 am | |
| Need this stuff taken off (especially vats) ASAP. Whats the cheapest route? 1996 motor being run as a 96. All stock internals. On a super budget. Should I send or buy equipment and do it myself?
| | | IMPALADAKID Admin
| Subject: Re: Cheapest way to remove VATS. EGR, AIR, o2's. from obd2 pcm Sun Jul 21, 2013 7:48 am | |
| I am thinking a three pound sledge hammer. Just use it to hit the PCM several times. When your done, that stuff and many others should all be deleted. J/K I have nothing. _________________ 1980 Cadillac Coupe DeVille. 6.0 87k 2017 Chevrolet Silverado LT 4.3 Aluminum V6 (My daily) 2008 Saab 9.3 convertible (Wife's Daily)
| | | 95brmw
| Subject: Re: Cheapest way to remove VATS. EGR, AIR, o2's. from obd2 pcm Sun Jul 21, 2013 8:19 am | |
| No cheap or easy way to do it yourself. Any reason to run an obd ii PCM? Drop a 94/95 one in there, swap the knock sensors and tune it. | |
| | | Ironfistdog
| Subject: Re: Cheapest way to remove VATS. EGR, AIR, o2's. from obd2 pcm Sun Jul 21, 2013 9:44 am | |
| Trans is a 96 and all I have is 94 pcm's. I'd also like to retain the obd2 reader since I can't seem to find anything that plugs into obd1 and read/clear codes. | |
| | | bfurches
| Subject: Re: Cheapest way to remove VATS. EGR, AIR, o2's. from obd2 pcm Sun Jul 21, 2013 4:48 pm | |
| - Ironfistdog wrote:
- Trans is a 96 and all I have is 94 pcm's. I'd also like to retain the obd2 reader since I can't seem to find anything that plugs into obd1 and read/clear codes.
You buy the credits, I will tune it out. Credits are 100.00 for hptuners. Cheapest route I can think of.... | |
| | | Ironfistdog
| Subject: Re: Cheapest way to remove VATS. EGR, AIR, o2's. from obd2 pcm Sun Jul 21, 2013 5:03 pm | |
| Sounds like a plan. $100 is cheap, I just didn't wanna be paying $200+ As soon as I get the motor ready to drop in I'll be out to have it done.
Should I keep or remove the evap? | |
| | | bfurches
| Subject: Re: Cheapest way to remove VATS. EGR, AIR, o2's. from obd2 pcm Sun Jul 21, 2013 5:33 pm | |
- Sounds like a plan. $100 is cheap, I just didn't wanna be paying $200+
Should I keep or remove the evap? I remove all of the emissions components when I tune or perform a swap. Just jump on to HPTuners.com and make sure the model/ year pcm you are using is compatible with there credits. | |
| Subject: Re: Cheapest way to remove VATS. EGR, AIR, o2's. from obd2 pcm | |
