» Anybody out there?
8.5 10 Bolt Housing EmptyYesterday at 10:41 am by BostonChevy
8.5 10 Bolt Housing EmptyWed Oct 19, 2022 1:27 pm by scot
8.5 10 Bolt Housing EmptyTue Oct 18, 2022 8:58 pm by silverfox103
8.5 10 Bolt Housing EmptyTue Sep 28, 2021 11:01 pm by silverfox103
8.5 10 Bolt Housing EmptyFri Sep 24, 2021 9:53 am by ElKy
8.5 10 Bolt Housing EmptySun Sep 19, 2021 6:22 pm by black blur 96
8.5 10 Bolt Housing EmptySun Jun 20, 2021 11:37 am by scot
8.5 10 Bolt Housing EmptyFri Jun 11, 2021 10:41 am by scot
8.5 10 Bolt Housing EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
May 2024
 8.5 10 Bolt Housing
5 posters
PostSubject: 8.5 10 Bolt Housing   8.5 10 Bolt Housing EmptyMon Oct 22, 2012 8:59 am
Spare housing from a Roadmaster Sedan. The posi chuck is blown up and will need to be replaced, but this is a good core for someone who wants to build a rear. I do have the axles as well (30 spline). 8.5 ring gear housing, with speed sensor on pinion.
100 come get it.
PostSubject: Re: 8.5 10 Bolt Housing   8.5 10 Bolt Housing EmptyMon Oct 22, 2012 9:37 am
Are the roadie sedans the narrower rear?
PostSubject: Re: 8.5 10 Bolt Housing   8.5 10 Bolt Housing EmptyMon Oct 22, 2012 7:00 pm
Yea steve...I believe it is. It is the same width as my oem boxy 9c1 rear. I could tape it for an exact number if you need?
PostSubject: Re: 8.5 10 Bolt Housing   8.5 10 Bolt Housing EmptyMon Oct 22, 2012 7:55 pm
Not to side track, but I've got a question...
When you say narrow, I think narrow like my '96 9C1.
I was not aware that the roadie was narrow too.
I'd like for you to post the width for comparison reasons.
I didn't think box 9C1 cars got a narrow (snow chain) rear end.
Maybe it's the fender skirt (91/92) that started it.
Bangshiftbrian's Buford T Justice 9C1 seems to be dead on matched to the front in the matter of width.
But, that could just be picture mirage type stuff.
...not stated as a question, but this isn't jeopardy
(Who is John Cafferty and the Beaver Brown Band) jocolor
PostSubject: Re: 8.5 10 Bolt Housing   8.5 10 Bolt Housing EmptyMon Oct 22, 2012 7:56 pm
8.5 10 Bolt Housing JiFa-French%20Stewart
PostSubject: Re: 8.5 10 Bolt Housing   8.5 10 Bolt Housing EmptyMon Oct 22, 2012 8:19 pm
Excellent! Best one by far IMO.
PostSubject: Re: 8.5 10 Bolt Housing   8.5 10 Bolt Housing EmptyMon Oct 22, 2012 10:04 pm
OK found it.
Actually, I need to put together a bullet proof rear for my DD impala.
We may need to talk once the weather changes & things calm down.
Anyway....
Quoting Bill Harper....cuz....you dont get better info then that.
"Chevy
91-92 sedan
1566mm - narrow (all)
93-96 sedan
1566mm - narrow (9C1 - disc & drum & some other drum applications)
1598mm - wide (Impala SS - disc & B4U - drum)
Buick 91-96 & Fleetwood 93-96 sedans
NOTE: Fleetwood housing is unique to the application - 4-channel ABS provisions
91-96 wagon, all
1642.5mm
All 93-96 7.625" (ring gear) housings are 1598mm wide (Chevy sedan only)
Sedan housings, in both widths, have the same lower control arm bracket location/spread distance, and will fit any other sedan frame. Wagons have a wider spread distance (approx. 2") between lower control arm brackets on housing, and corresponding wider frame lower control arm mounts."
^^^Ask Crovo how this swap fits^^... Arrow
PostSubject: Re: 8.5 10 Bolt Housing   8.5 10 Bolt Housing EmptyMon Oct 22, 2012 10:20 pm
Great info Steve. Exactly what I was asking!
Cut and pasted for good measure.
Thanks!
PostSubject: Re: 8.5 10 Bolt Housing   8.5 10 Bolt Housing EmptyMon Oct 22, 2012 11:31 pm
If anyone else cares, all of the 93-96 Chevy sedan rears are wide except for the 9c1 cars. So the civies without the B4U package are wide too. Smile
Oh, and by the way, Turd Ferguson, s'a funny name...
8.5 10 Bolt Housing 02-15-turd-ferguson_full_600
PostSubject: Re: 8.5 10 Bolt Housing   8.5 10 Bolt Housing EmptyMon Oct 22, 2012 11:48 pm
Lmaooooo
8.5 10 Bolt Housing
» Looking for 96 style opti housing
» Do all of these cars have the same rear end housing?
» N97 Bolt
» bolt in rear brackets w/ bags.
» 8.5 10 bolt rebuilt
