| N97 Bolt | |
+4MASShole9C1 toomanytoyz Tomz9C1 Cadet57 8 posters |
| Subject: N97 Bolt Sat Feb 18, 2012 4:43 pm | |
| Does anyone know what size the bolts are that hold the N97 caps to the rim? Are they still made? I've lost a few so I need to replace those/ like to have a few extras. | |
| Subject: Re: N97 Bolt Sat Feb 18, 2012 5:01 pm | |
| Bet ya Billy Mac knows Google Search is your friend. http://parts.nalleygmc.com/showAssembly.aspx?ukey_product=2539743&ukey_assembly=367457 | |
| Subject: Re: N97 Bolt Sat Feb 18, 2012 5:24 pm | |
| - Tomz9C1 wrote:
- Bet ya Billy Mac knows Google Search is your friend.
http://parts.nalleygmc.com/showAssembly.aspx?ukey_product=2539743&ukey_assembly=367457 I wish I did. I would take one off, hit an Ace hardware store and buy 12 new stainless bolts, and a small tube of threadlock. |
| Subject: Re: N97 Bolt Sat Feb 18, 2012 5:31 pm | |
| I never had luck getting the right thread on those. I got metrics and standards when I had my red winter wheels, and neither were "right" but both would work. Same with the ones on Big Ugly. Weird.
I wanna say m8x1.25 or 5/16-20 work, but don't hold me to it. _________________ Bill "The Verb" Crovo - Resident Car Slut & Unicorn Hunter A Toasted Marshmallow, A Long German, A Lame Suburban and expensive dreams... Missing all my previous B's, D's and V... American Ricerwww.badassofne.net "Ooooh! Look! Something shiny!"NO MORE UNICORNS!!!!!LOWER IT!!! | |
| Subject: Re: N97 Bolt Sat Feb 18, 2012 7:39 pm | |
| Tried to order 12 (figure that would hold me for a while) of them but there is a min order of $35 http://www.gciron.com/ShoppingCart.asp Who wants to get in on a group purchase? We would have to order 47 of them to break us over $35. I can ship it to one of the Bill's if that is ok? | |
| Subject: Re: N97 Bolt Sat Feb 18, 2012 7:49 pm | |
| - Tomz9C1 wrote:
- Tried to order 12 (figure that would hold me for a while) of them but there is a min order of $35
http://www.gciron.com/ShoppingCart.asp Who wants to get in on a group purchase? We would have to order 47 of them to break us over $35. I can ship it to one of the Bill's if that is ok? Your link has nothing in the shopping cart, and you can use my address to send them to if you like. |
| Subject: Re: N97 Bolt Sat Feb 18, 2012 7:50 pm | |
| Cheap here on eBay . Buy it now, free shipping for all 12 http://www.ebay.com/itm/12-Caprice-9C1-Center-Cap-Bolts-1994-96-Police-2000-10-/390348621212?hash=item5ae297459c&item=390348621212&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr | |
| Subject: Re: N97 Bolt Sat Feb 18, 2012 10:37 pm | |
- I never had luck getting the right thread on those. I got metrics and standards when I had my red winter wheels, and neither were "right" but both would work. Same with the ones on Big Ugly. Weird.
I wanna say m8x1.25 or 5/16-20 work, but don't hold me to it. I think this^^^ I remember MDZ nailed the bolts but I cant find the thread I did try 5/16-18 (also tried tapping) that was wrong, close but wrong. For some reason, I think he said it could be either (metric or std)? So that puts Crovo's guess right on the money Except I think its 5/16-24 ( I cant talk metric need to make a chart 4 myself sometime) _________________ Steve 96BBB 28K 3.42 Bolt-ons 95BBB 100K 3.73 383 New DD...already broke fixt the 4L60E twice 95 Black WB4 Hole...ee...grail 96 Black WB4 No holes in this 95BBB 189K 3.08 Old DD Stolen...by Matt. Whine..eee...Silver LS6 | |
| Subject: Re: N97 Bolt Sun Feb 19, 2012 6:42 am | |
I wanna say m8x1.25 or 5/16-20 work, but don't hold me to it. I think this^^^ I remember MDZ nailed the bolts but I cant find the thread I did try 5/16-18 (also tried tapping) that was wrong, close but wrong. For some reason, I think he said it could be either (metric or std)? So that puts Crovo's guess right on the money Except I think its 5/16-24 ( I cant talk metric need to make a chart 4 myself sometime) Yeppers, I forgot about that post. https://badass-of-ne.forumotion.com/t2878-9c1-center-caps#32643SdStick is correct, there are but two std (common) USA 5/16 Dia. bolt T.P.I.s (threads per inch) [5/16"/18 (coarse)] - & - [5/16"/24 (fine)] If there IS a 5/16"/20, it is a special purpose thread pitch. Every N97 I've ever seen was 8mm 1.25 mm/thread pitch. The ARP #s are [761-1001 (6 point)] - & - [771-1001 (12 point wrenching head)] 10 mm wrench, & both are 20mm UHL (under head length). For ref: [8mm = 0.3149062992125"] - and - [5/16" = 7.9375mm] - - - pretty close actually. Its the T.P.I. mismatch that will cause the binding and/or seizing for the wrongly sized installed threaded bolt. I got these (NOS) bolts (linked below) from Mike at Hamilton Chevrolet. Excellent GM parts source! http://www.ebay.com/itm/12-Caprice-9C1-Center-Cap-Bolts-1994-96-Police-2000-10-/390348621212?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item5ae297459c#ht_753wt_1165 Two important things to keep in mind: 1) - Stock (OEM) caps are reasonably sturdy die cast metal and don't crush that easily when the three bolts are tightened. However, the aftermarket plastic "knock-offs" are of a soft plastic and WILL crush when great care is NOT taken when tightening the screws! Use red lock tight when the exact bolt preload is reached, otherwise the low preload will allow the nice ARP bolts to fall out. 2) - You MUST be careful of the under-head bolt length, because the threaded bolt must NOT be too long, and protrude into the flat mounting pad area on your brake disc, drum, hub etc. If you are not careful, the wheel will not seat properly when mounted to the car. Note: I think the original bolts were 3/4" long, but you will have to double check that. 19mm is very close to 3/4" and 0.750" is actually 19.05mm. The above ARP part #s will be nearly 1 mm longer than OEM. | |
SPCS
| Subject: Re: N97 Bolt Sun Feb 19, 2012 9:19 am | |
| GM lists the bolts as M8x1,25x21 | |
| Subject: Re: N97 Bolt Sun Feb 19, 2012 9:45 am | |
http://www.gciron.com/ShoppingCart.asp Who wants to get in on a group purchase? We would have to order 47 of them to break us over $35. I can ship it to one of the Bill's if that is ok? Well, I'd be down for 24. But your link doesnt show a price each. I figure I'll get a nice new set for my 15x8's and my bro's N97's if they're cheap enough. - Machine-De-Zine wrote:
Thanks as always - SPCS wrote:
- GM lists the bolts as M8x1,25x21
Danke | |
| Subject: Re: N97 Bolt Sun Feb 19, 2012 9:55 am | |
| Subject: Re: N97 Bolt Sun Feb 19, 2012 9:57 am | |
| - MASShole9C1 wrote:
- Same eBay link I posted.
$29 for a set of 12? | |
| Subject: Re: N97 Bolt Sun Feb 19, 2012 10:11 am | |
$29 for a set of 12? Yea. Whats wrong with paying for OEM? Call me stupid, but I'd have done it already. Took out the guess work for me. | |
| Subject: Re: N97 Bolt Sun Feb 19, 2012 10:17 am | |
$29 for a set of 12? Yea. Whats wrong with paying for OEM? Call me stupid, but I'd have done it already. Took out the guess work for me. The only problem for me is I can never find OEM for a box | |
| Subject: Re: N97 Bolt Sun Feb 19, 2012 10:21 am | |
| Very true. If you do its $$$. But Mostly unfounded. So, swap to the LT1 and frame and all for ease of availability lol. J/K | |
| Subject: Re: N97 Bolt Sun Feb 19, 2012 11:05 am | |
- Cheap here on eBay . Buy it now, free shipping for all 12
http://www.ebay.com/itm/12-Caprice-9C1-Center-Cap-Bolts-1994-96-Police-2000-10-/390348621212?hash=item5ae297459c&item=390348621212&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr .76 Cents / Bolt x 48 = $36.48 + shipping. Beats the heck out of the e-bay I would think? | |
| Subject: Re: N97 Bolt Sun Feb 19, 2012 11:46 am | |
| Tom, If you do that count me in for 16 min (more if you need me to) _________________ Steve 96BBB 28K 3.42 Bolt-ons 95BBB 100K 3.73 383 New DD...already broke fixt the 4L60E twice 95 Black WB4 Hole...ee...grail 96 Black WB4 No holes in this 95BBB 189K 3.08 Old DD Stolen...by Matt. Whine..eee...Silver LS6 | |
| Subject: Re: N97 Bolt Sun Feb 19, 2012 11:50 am | |
- Tom,
If you do that count me in for 16 min (more if you need me to) Ill be down for 24. | |
| Subject: Re: N97 Bolt Sun Mar 11, 2012 7:18 pm | |
| Tom, you still going to order these? If not lmk so I can plan accordingly. Thanks! | |
| Subject: Re: N97 Bolt | |
| N97 Bolt | |
