I broke an effing bolt! EmptyWed Oct 19, 2022 1:27 pm by scot
I broke an effing bolt! EmptyTue Oct 18, 2022 8:58 pm by silverfox103
I broke an effing bolt! EmptyTue Sep 28, 2021 11:01 pm by silverfox103
I broke an effing bolt! EmptyFri Sep 24, 2021 9:53 am by ElKy
I broke an effing bolt! EmptySun Sep 19, 2021 6:22 pm by black blur 96
I broke an effing bolt! EmptySun Jun 20, 2021 11:37 am by scot
I broke an effing bolt! EmptyFri Jun 11, 2021 10:41 am by scot
I broke an effing bolt! EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
I broke an effing bolt! EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
4 posters
PostSubject: I broke an effing bolt!   I broke an effing bolt! EmptyTue Sep 18, 2012 4:05 pm
so last nite while trying to remove my egr tube I broke the head off the lower bolt going into the exhaust manifold.. No
I left the upper nuts tight which seems to be holding the tube in place (so far). My plan is to remove the erg tube all together.
I REALLY don't want to try and remove the exhaust manifold to tap out the broken bolt. My thought is to make a steel (not the aluminum one I have from ebay) block-off plate to have welded to the manifold. Has anyone had this issue and/or have any suggestions?
PostSubject: Re: I broke an effing bolt!   I broke an effing bolt! EmptyTue Sep 18, 2012 5:05 pm
Yup, this happened to me on both the sedans, removing the mainfolds to fix the broken bolts in the heads.
Repaired it the same way I did the brken bolts in the heads, Mig welder.
Hold a nut with vise-grips over the broken bolt, and weld the bolt to the nut.
Took a few tries, but I got em. If they are really stubborn, weld first, then heat the are with a torch. cheers
PostSubject: Re: I broke an effing bolt!   I broke an effing bolt! EmptyTue Sep 18, 2012 8:23 pm
X2. I have done the same thing twice, and drilled and tapped once. Weld works better.
PostSubject: Re: I broke an effing bolt!   I broke an effing bolt! EmptyWed Sep 19, 2012 12:33 am
» N97 Bolt
» UPS BROKE MY TRANS!
» So broke I can't pay attention, yet..........
» So, someone apparently broke into my car last Friday.
» So Now My Temp Gauge Broke... You have to be kidding...
