| Subject: I broke an effing bolt! Tue Sep 18, 2012 4:05 pm | |
| so last nite while trying to remove my egr tube I broke the head off the lower bolt going into the exhaust manifold.. I left the upper nuts tight which seems to be holding the tube in place (so far). My plan is to remove the erg tube all together. I REALLY don't want to try and remove the exhaust manifold to tap out the broken bolt. My thought is to make a steel (not the aluminum one I have from ebay) block-off plate to have welded to the manifold. Has anyone had this issue and/or have any suggestions? | |
| Subject: Re: I broke an effing bolt! Tue Sep 18, 2012 5:05 pm | |
| - mikiehews wrote:
- so last nite while trying to remove my egr tube I broke the head off the lower bolt going into the exhaust manifold..
Yup, this happened to me on both the sedans, removing the mainfolds to fix the broken bolts in the heads. Repaired it the same way I did the brken bolts in the heads, Mig welder. Hold a nut with vise-grips over the broken bolt, and weld the bolt to the nut. Took a few tries, but I got em. If they are really stubborn, weld first, then heat the are with a torch. | |
IMPALADAKID Admin
| Subject: Re: I broke an effing bolt! Wed Sep 19, 2012 12:33 am | |
| Subject: Re: I broke an effing bolt! | |
