- 94classicss wrote:
- 1986 k5 blazer crate 350 with under 500 miles ,rebuild th400 and transfer case ,new seals in rear and front axles and a folder of all the receipts and dates of replacements
the bad......... floors and rockers are GONE someone replaced them at one point and only painted the tops of them then placed a brand new carpet and pad over them. what floors were left are stuck to the bottom of the carpet with what little paint was used.
its going to be a off road truck so it doesnt have to be nice looking
im just gana cut what little rockers there are out and weld in some 3X2 square tube then tie the floors in to that nothing a welder and some metal cant fix
You have quite a nice truck there, with lots of potential.
Anything you need can be found used, new - NOS or aftermarket, you just have to search a little bit on some things.
Try this place: http://www.lmctruck.com/features/cc/cc.htm
Heres a photo of my truck after the town came down and made me take off two of the rear wheels.
It seems that a dually constitutes a commercial vehicle, and I'm allowed only one in plain sight on the property.
I think this body style is second only to the 1969-1970 models.
"Frankenstein" Project Truck
1982 C7E (HD-option) 1 ton dually "tall" chassis
1970 4 bolt main 4.290" bore big block 4.000" stroke (454 C.I.D. +.040" over)
1969 "063" oval port heads - worked - 1.88" & 2.19 SS valves. Crane Hyd (retro) roller cam
Holley strip Dominator intake, 850 D/P mechanical sec., Hooker ceramic coated headers.
1990 P-30 HD Rockwell 12" disc brake rear axle, 10 lug, 5.13:1 rear, Detroit No-Spin
1987 Muncie 465 manual trans & 12" clutch
1979 NP 205 all gear transfer case with bolt on Spicer 1410 yoke (no slip joint)
Dana 60 HD front axle with Detroit locker and 5.13:1 Richmond gears
All rebuilds were done with NOS GM parts, body - chassis - drivetrain
Whole project on hold, perhaps this thread will inspire me to get this thing running
