Subject: need some motor advice Tue Dec 13, 2011 1:55 pm
i just picked up a set of trans am heads this weekend. and iam ordering my cam for christmas. planing on jhaving the heads re-worked ported/polished. ordering a 306 comp cam,1.6 rr's new springs,rods.ect... also getting a ported/polished intake. my question is what size/brand injectors should i run and what size/brand throttle body?? thanks
Subject: Re: need some motor advice Tue Dec 13, 2011 3:46 pm
Sounds to me like some SVO 36lb injectors and a 52mm TB, and a pump and tune to support, by the sounds of your mods.
This really sounds like a question for an engine builder like Golen or Elwyn. But Crovo or Jason can probably answer better than me.
Subject: Re: need some motor advice Tue Dec 13, 2011 3:50 pm
I'd take it right to Golen. Guy up here i know did the same as you, and the thing is a screamer. They really do a nice job from what i've seen.
Posts : 1691 Join date : 2009-03-12 Age : 53 Location : Southern, NH
Subject: Re: need some motor advice Tue Dec 13, 2011 4:00 pm
Mike, going to test out how strong the stock bottom-end is?
Subject: Re: need some motor advice Tue Dec 13, 2011 4:09 pm
And so it begins....
_________________ Steve
96BBB 28K 3.42 Bolt-ons 95BBB 100K 3.73 383 New DD...already broke fixt the 4L60E twice 95 Black WB4 Hole...ee...grail 96 Black WB4 No holes in this 95BBB 189K 3.08 Old DD Stolen...by Matt. Whine..eee...Silver LS6
Subject: Re: need some motor advice Tue Dec 13, 2011 4:52 pm
H aha yes we'll see what the stock 150k block can handle..
Subject: Re: need some motor advice Tue Dec 13, 2011 4:55 pm
I cheer it on!
I'm going to do much of the same thing. F-body heads, LT4 hot-cam, 1.6 rollers, 52 mm T.B. (I need injectors & a pump too). Not touching the bottom other than new bearings and some rod bolts.
I have a couple of block, cranks, rods. If it goes BOOM, oh well
Subject: Re: need some motor advice Tue Dec 13, 2011 5:04 pm
i have a 96 lt1 block and heads sitting in the corner just incase.. my only other question is where can i have the car tuned around here after its done??
Subject: Re: need some motor advice Tue Dec 13, 2011 5:30 pm
Crovo knows a guy
Subject: Re: need some motor advice Tue Dec 13, 2011 8:06 pm
Yeah, the SVO red tops should be what you want. And the Walbro 255. Sounds like a nice little screamer. Pretty much the same setup that I had in the SS that put 340 to the wheels. And yeah, I know a great tuner! He just did my truck tonight, actually.
As far as the 52mm TB, there is a guy on eBay that does them. Like $175 with your core, iirc. Used him twice. I have the second one sitting on the shelf waiting for the wagon swap this winter.
_________________ Bill "The Verb" Crovo - Resident Car Slut & Unicorn Hunter
A Toasted Marshmallow, A Long German, A Lame Suburban and expensive dreams... Missing all my previous B's, D's and V... American Ricer www.badassofne.net "Ooooh! Look! Something shiny!" NO MORE UNICORNS!!!!!
LOWER IT!!!
Subject: Re: need some motor advice Tue Dec 13, 2011 8:41 pm
Just throwing it out there but is there a mild cam that I could use and not get into replacing the injectors and fuel pump and all that jazz. Just aquired a set of fbody aluminum heads and 1.6 rr. Just want a little more umph but still have it be a pleasant daily driver.
Subject: Re: need some motor advice Tue Dec 13, 2011 9:20 pm
First off, the only gain you will get from stock aluminum heads is weight reduction. Stock cast iron b-body heads flow better. They help to move the heavier car around. However, the aluminum heads are easier to port, and gasket match. A mild cam like the hot cam, or 845 are stock fuel system friendly. The hot cam is a little more aggressive. The 846 is about the same as the hot cam, maybe a bit more aggressive. I would gasket match the heads to the intake, and some on the exhaust side, and polish the runners. Run a 846 cam with 1.6 rr, and a good tune. On a stock lower with stock intake, exhaust and fuel system, you should see decent numbers, that can be approved by upgrading the exhaust, and fuel system. Anyone of the cams mentioned will be very streetable.
Subject: Re: need some motor advice Tue Dec 13, 2011 11:09 pm
Mike, Not saying any advice is above is bad (i mean wtf do i know lol) But don't forget Machine-de-zine (Glen) is an engine builder so if you want a page long response of all rock solid great advice try to get in touch with him. He'll have some good ideas I bet.
I guess like with everything else it depends on how much you want to spend and how far you want to go.
Subject: Re: need some motor advice Fri Dec 16, 2011 12:40 pm
Ok so after Christmas iam ordering svo 36lb injectors, 225 fuel pump, 306 roller cam with roller lifters. 1.6 rr's, hardened pushrods. Portered intake 52mm tb
Subject: Re: need some motor advice Fri Dec 16, 2011 1:44 pm
..... well dam!...... 3M vinyls is a cash cow?
Subject: Re: need some motor advice Fri Dec 16, 2011 1:48 pm
Guess he's planning on a Xmas bonus
Subject: Re: need some motor advice Fri Dec 16, 2011 2:50 pm
...or some side work.
LOWER IT!!!
Subject: Re: need some motor advice Fri Dec 16, 2011 3:01 pm
Crap!!!...I knew I shoulda got a price before I said go!!!
Subject: Re: need some motor advice Fri Dec 16, 2011 4:05 pm
Gotta be careful with those bonus checks
Subject: Re: need some motor advice Sat Dec 17, 2011 7:20 am
Subject: Re: need some motor advice Tue Dec 20, 2011 11:18 am
Ok.. so I have figured everything out for parts. But with the svo 36lb injectors what do I do for a pressure regulator? Replace my stock with a after market one? Or go broke and go full braided line with an fitting welded to the fuel rails?
