March 2018
 advice needed
PostSubject: advice needed   Sun Oct 24, 2010 4:15 pm
What's the best way to remove seized caliper bolts? The bolts are frozen tight and the allen bit won't stay locked in enough to get all my weight into it. I don't have air tools or a torch so take that into consideration.
PostSubject: Re: advice needed   Sun Oct 24, 2010 4:22 pm
PbBlaster & taps with a brass drift pin (or something)
Patience & repeated blasts & taps will free it up
Vibration is the enemy of rust
Is the allen part rusted up inside? Clean that up if you can
95 Black WB4
95BBB 189K 3.08 Old DD Matt. Cool
PostSubject: Re: advice needed   Sun Oct 24, 2010 8:46 pm
as was mentioned clean the allen head out so the key fits in as far a possible,. remember it needs to turn to the right as you,re looking at it,.with the allen key in tight,.hit it with a heavy hammer in the direction you need to go,.
PostSubject: Re: advice needed   Sun Oct 24, 2010 8:49 pm
The allen part is cleaned out, but it's going to start stripping soon. I used some PB while I was working on it. Also tried the hammer on the end of the bolt, the head of the bolt, the fitting while it was in the bolt. Got alot of rust to flake off but it didn't loosen up. I'll try again in a couple days and see if I make better progress. The passenger side was a bit stuck but the drivers side feels like it was put in with an impact gun and no lube.
PostSubject: Re: advice needed   Sun Oct 24, 2010 9:42 pm
try some vise grips
advice needed
» Miracle Bristlenose Baby!! Advice Needed Please??
» Witch Hunter advice needed
» advice needed coastal redwood
» Advice needed - Replacing LGB hook/loops with more realistic couplings
» blue spruce-advice needed
