| Subject: power antenna motor problem Wed Jul 20, 2011 4:07 pm | |
| When I turn the car off, key out of the ignition, the antenna motor continues to click every so often. The car sat for a month and the motor killed the battery to the point it was worthless to charge. At the moment, I have the harness connector near the engine fuse box disconnected, no radio reception . Is there a relay, where is it located, and is this a somewhat common problem? | |
| Subject: Re: power antenna motor problem Wed Jul 20, 2011 4:28 pm | |
| Just pulled the power to my DD just like you. Same problem, same result. I was thinking of just adding a toggle to the power in so I can use it and shut it down when its sitting. Bush league fix but easy & effective
edit: I think there's an internal limit switch thats efing up so it never knows its down all the way. I have another antenna that I was going to open up, I just hate to bust it | |
