| Author | Message |
SScarlett_Caprice
Posts: 66 Join date: 2010-03-14 Age: 22 Location: Gales Ferry, CT
 | Subject: Transmission lines Sun Feb 13, 2011 3:15 pm | |
| is there any way to temporarily fix the leaky metal crimps on the transmission cooler lines in my car? if not where can i order new lines? when i had my roadmaster i bought some from the dealership i work at and they were insanely expensive. |
Posts: 1221 Join date: 2009-01-21 Age: 50 Location: Rumford, Maine
 | Subject: Re: Transmission lines Sun Feb 13, 2011 4:06 pm | |
| Year,make,model,engine? Just replaced all lines on my 94 9C1. This website will show you what you need. http://www.compnine.com/index.php |
Posts: 3933 Join date: 2009-07-30 Age: 31 Location: Reading, MA
 | Subject: Re: Transmission lines Sun Feb 13, 2011 5:01 pm | |
| Where's it leaking? Is it somewhere along the line itself? On my white Caprice, I had a pinhole rot through one of the lines up under the front of the engine- I got a length of transmission cooler line hose from Advance which had an inner diameter that slid over the outer diameter of the line, cut out a bad section of line, and just double clamped the rubber hose on each end. It's worked fine ever since. |
 | Subject: Re: Transmission lines Sun Feb 13, 2011 11:36 pm | |
| | Matt Trakker wrote: | | Where's it leaking? Is it somewhere along the line itself? On my white Caprice, I had a pinhole rot through one of the lines up under the front of the engine- I got a length of transmission cooler line hose from Advance which had an inner diameter that slid over the outer diameter of the line, cut out a bad section of line, and just double clamped the rubber hose on each end. It's worked fine ever since. |
That will work as a "quick fix". If there is 1 pinhole now, you can bet there's another right behind it. |
 | Subject: Re: Transmission lines Mon Feb 14, 2011 12:45 am | |
| | Tomz9C1 wrote: | | Matt Trakker wrote: | | Where's it leaking? Is it somewhere along the line itself? On my white Caprice, I had a pinhole rot through one of the lines up under the front of the engine- I got a length of transmission cooler line hose from Advance which had an inner diameter that slid over the outer diameter of the line, cut out a bad section of line, and just double clamped the rubber hose on each end. It's worked fine ever since. |
I know- I replaced like a foot of the line in question though just in case |
Posts: 1826 Join date: 2009-01-21 Age: 26 Location: NH
 | Subject: Re: Transmission lines Mon Feb 14, 2011 1:44 am | |
| Somebody recently posted photos on that other forum of lines from inline or classic tube. |
SScarlett_Caprice
 | Subject: Re: Transmission lines Mon Feb 14, 2011 3:30 am | |
| tomz9c1, i think you just found me my new favorite website. ive never seen so many diagrams in one place! they are fairly determined that the 94-95 b bodys were available with a v6 and a 5 speed tho....
anyway its a 1995 caprice LT1, and all of the cooler lines have built up nasty oil around the metal crimps where it goes from a hard line to a soft line, but the one thats actually making a puddle on the driveway is on the drivers side right before it passes under the distributor.
Posts: 3543 Join date: 2009-03-20 Location: Revere, MA
 | Subject: Re: Transmission lines Mon Feb 14, 2011 4:27 am | |
| | SScarlett_Caprice wrote: | anyway its a 1995 caprice LT1, and all of the cooler lines have built up nasty oil around the metal crimps where it goes from a hard line to a soft line, but the one thats actually making a puddle on the driveway is on the drivers side right before it passes under the distributor.
Its only a matter of time before that happens. Replace the lines ( & wait a little while before it happens again) OR use AN braided lines & fitting to get rid of this PIA occurance. I have saved the P/N's (from Hussker the other forum) Not sure how expensive it is, but I've been dying to do it. PM me if you want those P/N's (theyre at home) THESE are from someone else (sorry dont remember & didnt copy thier name) THESE arent the braided but MAY be cheaper
Again if you are tired of the leaking crimps on the cooler lines for the oil and trans coolers in the radiator here are the part numbers to swap them out to something that doesn't leak.
Here are the Jegs part numbers that will replace the crimps and rubber lines on the transmission side. You need to use the Push Loc hose with these fittings or there is another style that is braided stainless style. But only those two. Any other type of hose might not stay locked on the fittings.
555-110051 - Qty 4 - #6 STR PUSH LOC BLACK 555-110551 - Qty 4 - #6 MALE TO 3/8" TUBE BLK 555-102010 - Qty 1 - #6 PUSH LOC HOSE 5' BLK
_________________ Steve  96BBB 28K 3.42 Bolt-ons 95BBB 100K 3.73 CAI stock New DD Assembling now 95 Black WB4 Hole...ee...grail 95BBB 189K 3.08 Old DD Stolen...by Matt.  |
SScarlett_Caprice
 | Subject: Re: Transmission lines Mon Feb 14, 2011 5:21 am | |
| | sdstick wrote: | | SScarlett_Caprice wrote: | anyway its a 1995 caprice LT1, and all of the cooler lines have built up nasty oil around the metal crimps where it goes from a hard line to a soft line, but the one thats actually making a puddle on the driveway is on the drivers side right before it passes under the distributor.
I think im going to use the jegs parts, money is a big issue right now and i doubt i can afford the braided lines. the big problem right now is the oil cooler lines to the radiator on the drivers side, can i use the same parts just more of them for that?
 | Subject: Re: Transmission lines Mon Feb 14, 2011 6:59 am | |
| http://www.impalassforum.com/vBulletin/showthread.php?p=2466215 |
 | Subject: Re: Transmission lines Mon Feb 14, 2011 7:19 am | |
| If you are also having an issue with the oil coolerside rubber lines and crimps you can use the following along with the left over hose from the Trans side (get a longer #6 hose if you are replacing much more then the stock lengths). 555-110212 - Qty 2 -#6-#8 FLARE REDUCER BLK 555-110051 - Qty 4 - #6 STR PUSH LOC BLK 555-110552 - Qty 2 - #8 FEMALE TO 1/2" TUBE BLK 555-110551 - Qty 2 - #6 MALE TO 3/8" TUBE BLK Once again I copied this. From the block (oil adapter) to the block side of the rubber hose is 1/2" on the oil cooler then the rubber hose crimp downsizes to the 3/8" again going to the radiator. Alot of times the fitting into the radiator has no intention of coming out. If thats your case, your doomed to assembling this on the car....no big deal. Good luck. We expect prices & pics asap.... Available Hose Sizes -2 -3 -4 -5 -6 -8 -10 -12 -16 -20 Hose Size is the measurement of the Inner Diameter of the hose measured in units of 1/16th of an inch. Examples: a -2 hose has an I.D. of 1/8" [306 only] a -3 hose has an I.D. of 3/16" a -4 hose has an I.D. of 1/4" a -5 hose has an I.D. of 5/16" a -6 hose has an I.D. of 3/8" a -8 hose has an I.D. of 1/2" a -10 hose has an I.D. of 5/8" a -12 hose has an I.D. of 3/4" a -16 hose has an I.D. of 1" a -20 hose has an I.D. of 1 1/4" _________________ Steve  96BBB 28K 3.42 Bolt-ons 95BBB 100K 3.73 CAI stock New DD Assembling now 95 Black WB4 Hole...ee...grail 95BBB 189K 3.08 Old DD Stolen...by Matt.
onehunglo
Posts: 306 Join date: 2009-01-25 Age: 35 Location: Raymond, NH
 | Subject: Re: Transmission lines Mon Feb 14, 2011 8:44 am | |
| I just plugged mine up with some epoxy, hasn't leaked in a couple years. I do plan on deleting the lines this spring. |
 | Subject: Re: Transmission lines Mon Feb 14, 2011 12:03 pm | |
| I almost forgot.  I used the coupon code "VISA" and got $10 off oil cooler lines for the Suburban from Advance Auto. And they also have "RAD25" for %25 off a radiator. |
SScarlett_Caprice
 | Subject: Re: Transmission lines Mon Feb 14, 2011 3:00 pm | |
| ok this is all great, but since im broke as hell wouldnt it work just fine to put in new rubber hoses and hose clamp them to the hardline? |
 | Subject: Re: Transmission lines Mon Feb 14, 2011 3:22 pm | |
| | SScarlett_Caprice wrote: | | ok this is all great, but since im broke as hell wouldnt it work just fine to put in new rubber hoses and hose clamp them to the hardline? |
Use rubber fuel line, It is much stronger. |
| That would work until it doesnt. If it fails you lose oil & pressure. If you have no other choice, at least put a flare on the pipe to give it a fighting chance. I'd watch it like a hawk. _________________ Steve  96BBB 28K 3.42 Bolt-ons 95BBB 100K 3.73 CAI stock New DD Assembling now 95 Black WB4 Hole...ee...grail 95BBB 189K 3.08 Old DD Stolen...by Matt.  |
SScarlett_Caprice
 | Subject: Re: Transmission lines Mon Feb 14, 2011 3:31 pm | |
| that looks to be my only option until i can afford the proper setup, which will only be a week or two. thanks for all the help everyone, this week has been nothing but problems.... new water pump/drive oil seal, new timing chain cover gasget, cam seal, crank seal, and when i loosened my mechanical fan tensioner the wrench slipped and i put a pinhole in my radiator. |
 | Subject: Re: Transmission lines Mon Feb 14, 2011 3:56 pm | |
| Dude, that sucks! Maybe someone close has one you can use till you can replace it? |
 | Subject: Re: Transmission lines Mon Feb 14, 2011 4:40 pm | |
| The civi oil cooler lines are $48.99 at Advance Auto. If you order online and pick up at the store you can use a coupon code to get at least $10 off.
Are you sure it's not oil from the water pump seal? It's not that I doubt the oil cooler lines leak but oil from a bad pump seal gets just about everywhere.
edit: The 9C1 lines are around $38. |
SScarlett_Caprice
 | Subject: Re: Transmission lines Tue Feb 15, 2011 5:20 am | |
| the front of the engine is completly dry (or at least it is now) but you can actually watch some of the lines drip as the car idles. and the pinhole is no big deal, i have some stop-leak that will plug it up for a month or two until i can get a new radiator. i found one on summit racing for less than $200.
unless someone on here has a radiator they want to sell....? |
 | Subject: Re: Transmission lines Tue Feb 15, 2011 6:16 am | |
| I have 1 for a 9C1(non oil cooler) and 1 for a B4U(Oil cooler inc). They are not pretty but they are leak free, $35. PM me. |
