| Upper control arm to differential | |
| Subject: Upper control arm to differential Thu Oct 14, 2010 12:16 pm | |
| Anyone have experience with the pressed in bushing? I'm replacing the rear uppers & lowers. I have the new bushings but dread trying to remove the original. I've heard some leave the original in Let me know what you guys think. Thanks | |
| Subject: Re: Upper control arm to differential Thu Oct 14, 2010 12:46 pm | |
| Take them somewhere that has a large press. I have done some, and broke my small press doing it. Its not hard, just need the right tools. | |
| Subject: Re: Upper control arm to differential Thu Oct 14, 2010 12:51 pm | |
| These are the ones pressed into the axle. No WAY I'm carting that around I'll burn them out before it leaves here What I was wondering is if anyones kept the old without any problems. Doesnt seem like theres much deflection in the stock rubber, but under load I'm sure it moves. | |
| Subject: Re: Upper control arm to differential Thu Oct 14, 2010 1:47 pm | |
| Ah well I can see what you mean.
I put my new arms on the old bushings. Still nice and tight! | |
| Subject: Re: Upper control arm to differential Thu Oct 14, 2010 1:51 pm | |
| THAT'S what I wanted to hear Thanks Glen | |
| Subject: Re: Upper control arm to differential Thu Oct 14, 2010 1:57 pm | |
| Subject: Re: Upper control arm to differential Thu Oct 14, 2010 2:19 pm | |
| I've heard of people using a small blade sawz-all and running it through the bolt hole and just cutting a couple lines so that the bushing can basically just snap in half and be pulled out in 2 parts. That was a long sentence | |
| Subject: Re: Upper control arm to differential Thu Oct 14, 2010 2:30 pm | |
| Ya, mostly they just torch out the rubber center & punch the pressed in sleeve into the recess til it comes out. I just didnt want to go thru that if it wasnt completely necessary. Glen did what I was thinking & his is fine so I'm leaving the stock bushings in Thanks | |
| Subject: Re: Upper control arm to differential | |
