 Question on 7.5 vs 8.5 differential
PostSubject: Question on 7.5 vs 8.5 differential   Wed Sep 11, 2013 8:33 am
I need to know specifically what the difference is (if any) between the yoke's that hang out of the differential 7.5" bs 8.5".
Are the bolts that hold the u-joints to the yoke spaced the same between 7.5 vs 8.5?
Anyone have a 7.5" and can take a measurement for me?
PostSubject: Re: Question on 7.5 vs 8.5 differential   Wed Sep 11, 2013 9:06 am
Well I'll tell you what I know and hope that answers everything.
7.5 & 8.5 diff's have the same internal snap-ring 3R u-joints, straps, and bolts.
On a b-body the 7.5 driveshaft in at least an inch longer
I think the only difference in the yoke itself is the size of the splined hole where the pinion goes thru (but may actually be the same)
PostSubject: Re: Question on 7.5 vs 8.5 differential   Wed Sep 11, 2013 9:17 am
Thought there was a 27 vs 30 teeth thing going on too?
Not that that matters for Indys question....
I saw it in the parts book onetime....91-96...drums...disc....depending on code
PostSubject: Re: Question on 7.5 vs 8.5 differential   Wed Sep 11, 2013 9:27 am
So if I buy a 40 tooth reluctor that bolts to a 7.5" differential yoke, it should also bolt to an 8.5" yoke?
(it uses the 4 bolts that attach the drive shaft to the rear end)
PostSubject: Re: Question on 7.5 vs 8.5 differential   Wed Sep 11, 2013 10:29 am
I'd wait until someone with a 7.5 in hand chimes in
Brophys always around & we know his 7.5 is accessible right?
PostSubject: Re: Question on 7.5 vs 8.5 differential   Wed Sep 11, 2013 10:30 am
Around '90 the 8.5 went from 28 spline axles to 30 spline (stronger)
10 bolt cover with 8.5" ring gear. Ring gear has 10 bolts and pinion has 30 spline. C/clip rear could have 28 or 30 spline axles. Sometimes referred to as the "GM 10-bolt".
PostSubject: Re: Question on 7.5 vs 8.5 differential   Wed Sep 11, 2013 10:32 am
I'd have no reason to think it wouldn't work Smile
PostSubject: Re: Question on 7.5 vs 8.5 differential   Wed Sep 11, 2013 4:55 pm
I've got a couple 7.5, didn't read the thread, but who needs one? Lol
PostSubject: Re: Question on 7.5 vs 8.5 differential   Wed Sep 11, 2013 7:45 pm
I just need to know if the measurement from bolt hole to bolt hole is the same on a 7.5" as it is on an 8.5"
Both across the u-joint straps (parallel) and across from strap to strap (perpendicular).
PostSubject: Re: Question on 7.5 vs 8.5 differential   Thu Sep 12, 2013 12:11 am
Get it to you tomorrow, either early as hell or late at night.
» gear differential putty
» Question on scrap dragon
» Ginkgo Question
» JK Question
