Subject: Wheel size info...need help Wed Oct 20, 2010 7:12 pm
Will a 5X5 bolt pattern 15x8 inch wheel fit on the 9C1? I need to know acceptable backspacing and offset. What Im looking at now has 3.300 in. center bore diameter, -19.00mm offset, and 3.750 in backspacing
Subject: Re: Wheel size info...need help Wed Oct 20, 2010 7:50 pm
Should fit. It's the same dimensions as the truck wheel and people use those all the time.
