 Hex bit size?
onehunglo
PostSubject: Hex bit size?   Fri Feb 27, 2009 1:31 pm
Anyone know what size hex bit is used for the brake calipers 96ss?
PostSubject: Re: Hex bit size?   Fri Feb 27, 2009 3:15 pm
3/8" maybe.... Lemme go look in the garage...
EDIT: Yup, looks like my 3/8" hex appears to be my most worn one. So that must be it. Smile
QwikImpSS
PostSubject: Re: Hex bit size?   Fri Feb 27, 2009 7:15 pm
Yes, it is a 3/8" hex....just to confirm....
onehunglo
PostSubject: Re: Hex bit size?   Sat Feb 28, 2009 6:40 am
sweet thanks, I was thinking either 3/8" or 10mm. I was diggin' some more on other club sites and I thought I found it was 10mm, so I ordered a set of metric bits from work. Hopfully that 10mm works, if not I have to get a set of SAE.
QwikImpSS
PostSubject: Re: Hex bit size?   Sat Feb 28, 2009 8:53 am
Either way, can't hurt to have the metrics and the standards.
I think the 10mm works but a better idea to use the 3/8".
I'm just glad our cars don't have threads in the caliper, I stripped come caliper threads once when I was working at a Chevy shop, that was an expensive mistake... pale
Hex bit size?
» Miniatures size or escale
» Mordheim Table Size
» Maximum Warband Size - House Rules
» Development size of female bristle nose and growth maturity ?
» different size rims
