| Need some A/C compressor advice for my 3800 Silhouette | |
| Subject: Need some A/C compressor advice for my 3800 Silhouette Mon Jul 12, 2010 11:58 am | |
| The A/C clutch is GONE in my Silhouette. The van has about 130 on it. I want to replace the compressor. Besides the compressor what else should I look at replacing, if anything? The whole system worked perfect until the clutch went. I don't want to just change the clutch and take a chance of the compressor blowing a week later so I want to do it now. Should the accumulator be changed? I hope not because my van has 2 of them and that will probably get costly. But, I NEED my personal daily driver back and I need my A/C. I am sick of sharing my Olds 88 with my girl. Hit me with some advice/suggestions.
BTW, I WILL NOT use any junk yard parts for my A/C fix that is out of the question. | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Mon Jul 12, 2010 12:16 pm | |
| If you refuse to run used parts then expect to pay a small fortune to get it fixed. Air conditioning components are generally pretty pricy. Plus all you can buy now are reconditioned parts that were rebuilt in mexico by little kids | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Mon Jul 12, 2010 12:30 pm | |
| I am not particularly worried about cost. I will pay for quality. Rock Auto is showing new GM compressors on the $300 range. | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Mon Jul 12, 2010 2:05 pm | |
| Tim
If you had no leaks and the AC worked good, I don't think you need to replace any other parts. If you bring it to a place to be recharged they can dye test it for leaks. Then if there is a problem replace what is needed.
Just last week I had to replace the condensor and accumulator with a recharge was just south of $500 on my Grand Marquis.
Tom | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Mon Jul 12, 2010 2:25 pm | |
| Thanks Tom, sounds good. There is a place a few houses down from mine that specializes in A/C systems. I will have them charge it up for me after I swap the compressor. | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Mon Jul 12, 2010 5:01 pm | |
| you will need a new drier and orifice tube with a compressor change,I got all my stuff here
http://www.ackits.com/merchant.mvc?Screen=SFNT&Store_Code=01 | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Mon Jul 12, 2010 5:32 pm | |
| My van has 2 driers so I should replace both of them? | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Mon Jul 12, 2010 6:00 pm | |
| yes their cheap $20 ? each | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Tue Jul 13, 2010 3:13 pm | |
| did you buy a compressor from them? What does the orifice tube do and where is it located? | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Tue Jul 13, 2010 3:17 pm | |
| yes I got a new compressor from them, the orifice tube is a filter and it is in one of the hard lines | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Tue Jul 13, 2010 3:20 pm | |
| Was it their reman compressor? How long have you had it?
So from what I gather, I need:
- Compressor with clutch
- 2 driers
- orifice tube
Anything else? Seals or something? Should I pay someone to evacuate the system or just let it loose....... | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Tue Jul 13, 2010 3:33 pm | |
| it was a new compressor that I put on 2 years ago. do it yourself plus get an o-ring kit , when you find the orifice tube if it has alot of metal on it you will need the condeser & evaporator flushed | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Tue Jul 13, 2010 3:42 pm | |
| Thanks bobby. I think I am going to go with the people you suggested. Going to get: NEW compressor with clutch Accumulator Orifice tube O-Ring kit I called GM parts dept. they said I only have 1 accumulator. It is 2 evaporators that I have. Everything look ok? | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Tue Jul 13, 2010 3:46 pm | |
| alot of the guys on the Impala forum have use them http://www.ackits.com/c/BlackDeath/Auto+AC+Compressor+Failure+%28Black+Death%29.html | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Tue Jul 13, 2010 3:48 pm | |
| Too bad your not going with used parts since you could strip the Toronado of all it's a/c if you wanted. Course it has a leak in it somewhere | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Tue Jul 13, 2010 3:53 pm | |
| The compressor itself I think is fine. The clutch is what went but I can't see myself having a new clutch installed on a compressor with 120k+ on it which is why I am replacing it. | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Tue Jul 13, 2010 3:57 pm | |
| - GasTT wrote:
- The compressor itself I think is fine. The clutch is what went but I can't see myself having a new clutch installed on a compressor with 120k+ on it which is why I am replacing it.
sounds good to me Timmy | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Mon Jul 19, 2010 12:59 pm | |
| Not having any luck with ACkits. They charged me $900 for a $300 order and then only credited me back $300. I called them and they are basically saying they don't owe me the other $300. I called my bank, now my bank has to send them a dispute form and I have to wait and wait and wait for my $300. Good thing I had the money in my account. | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Mon Jul 19, 2010 3:08 pm | |
| sorry to hear you had problems with them Timmy but I would never use my debt card on the internet go to their forum and give them bad feedback http://www.autoacforum.com/ | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Sat Jul 24, 2010 3:45 pm | |
| The money was returned and I received my items in a timely manner. I never did go leave them bad feedback and I'm glad I didn't. Everything is installed now and working excellent. My van is SUPER quiet now. Thanks for the recommendation Bobby. It saved me a bit of cash as I was about to order a GM unit from Rockauto for 300+. My whole order from ackits was around 300 TOTAL. I paid only 150 to have everything installed and the system charged. I just have 1 more problem to track down. While my old compressor was all messed up it blew the fuse for it and I cannot find it. The mechanic had to jump the relay to charge the system. Everything is working but that damn fuse that even the GM dealer I went to cant find. | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Sat Jul 24, 2010 3:52 pm | |
| On most of the ones I've seen there's a fuse inside the car for the climate controls, and theres a curcuit breaker in the aux fuse panel under the hood. It's possible that the breaker is bad. Either that or the relay itself isn't switching like it should. | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Sat Jul 24, 2010 3:54 pm | |
| The relay works perfect. The Idle even kicks up high but the compressor is not engaging. The fuse is no good and I can't locate it. I went to the GM dealer, had the parts counter guy AND a GM tech scratching their heads. "Our computer only goes back to '98". | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Sat Jul 24, 2010 3:55 pm | |
| thats good you got all your money back Timmy http://www.goldsswagon.com/diagrams/wiringindex.htm | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Sat Jul 24, 2010 3:59 pm | |
| Bring it by on a day off and I'll help you dig through and track it down. | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Sat Jul 24, 2010 5:32 pm | |
| - mean ss wrote:
- thats good you got all your money back Timmy
http://www.goldsswagon.com/diagrams/wiringindex.htm Bobby, this was for my 1994 Oldsmobile Silhouette. Thanks though. | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Sat Jul 24, 2010 5:33 pm | |
| - bammax wrote:
- Bring it by on a day off and I'll help you dig through and track it down.
I am unemployed so everyday is my day off when is good for you? I NEED MY AC NOW. | |
| oops | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Sat Jul 24, 2010 5:35 pm | |
| I am however going to use those diagrams to track down the electrical AC problem in my Caprice. | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Sat Jul 24, 2010 5:54 pm | |
| I'm free most days since I don't work. I do have to run Laura to and from work so any other time is open. I have time Monday and Wed-Fri. Just a matter of how late in the day that free time is. | |
danbook
Posts : 1 Join date : 2010-11-25
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Thu Nov 25, 2010 1:15 am | |
| - mean ss wrote:
- you will need a new drier and orifice tube with a compressor change,I got all my stuff here
http://www.ackits.com/merchant.mvc?Screen=SFNT&Store_Code=01 Hi I know this is an old thread but I need to know about auto parts especially with this A/C Orifice Tube? What does this thing do in the car? Actually I need to buy one and I found a store but of course before buying this item I need to know what does it do inside the car? I appreciate If someone could answer me..Thanks!
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette Thu Nov 25, 2010 2:20 am | |
| AC kits (Arizona Mobile Air) hosts an AC forum. | |
| Subject: Re: Need some A/C compressor advice for my 3800 Silhouette | |
