Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyWed Oct 19, 2022 1:27 pm by scot
Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyFri Sep 24, 2021 9:53 am by ElKy
Leftovers from 8 Impala part-outs...lots of good stuff left! EmptySun Sep 19, 2021 6:22 pm by black blur 96
Leftovers from 8 Impala part-outs...lots of good stuff left! EmptySun Jun 20, 2021 11:37 am by scot
Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyFri Jun 11, 2021 10:41 am by scot
Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
7 posters
PostSubject: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyMon Jun 28, 2010 3:43 pm
OK, I have parted out 8 Impalas and I have a loft full of goodies left over. Here is a semi complete rundown of what I have. I would love to clear some of this stuff out to make room and help fund the LS build in my 96.
All Prices are before shipping, please PM me with your zip and what items you need and I will get you a shipped quote.
All parts are from WX3 Impalas unless otherwise noted:
(2) 94-95 steering column - $50 each
(3) Radiators - $50 each
(3) AC Condensers - $35 each
(2) Steering Box - $75 each
(3) Radiator Overflow - (2) single nipple, (1) Double nipple - All have yellow hue would look best painted - $25 each
(4) Washer fluid tanks - All have yellow hue would look best painted - $25 each
(3) Sets of Cats (94-95) - $80 each set
(2) Lower Dash - $75 each (oversize shipping, be prepaired)
(2) Brake Booster - $25 each
(3) Dual Electric fan setup - $50 each
(1) Set 94 SS mirrors (Black) - $50 each
(3) Rear View mirror with map light - $20 each
(2) 95 PCM - $60 each
(1) 94 Camaro PCM - $60
(3) Wiper Motor - $20 each
(5) Keyless Entry Box with 1 fob - $25 each
(5) Twilight Sentinel boxes - $25 each
(1) 95 SS LT1 Engine Harness - $100
(3) Cluster Bezel - (1) with 2" VDO Tach. - $50, (2) Mint condish - $20
(1) Driver side airbag - $25
(3) Passenger Side Airbag - $25 each
(1) Airbag brain/controller - $25
(5) Steering Shaft - $20 each
(5) Climate Control boxes - (3) w/knobs - $35, (2) without knobs - $25
(1) Hood Cable - $15
(1) Glove Box - $20
(2) Trunk Net with plastic nuts - $25 each
(2) used K&N air filters - $10 each
(2) Sets of Visors - $25 each
(3) Glove box surrounds - $25 each
(1) Set 94 1/4 windows with plastic triangles - $150 for the set
(2) Driver side tail light (1) mint - $25, (1) black trim is pealing - $20
(1) Set 94-96 Caprice Tails - $35 for the set
(2) Heater Hose set with good T - $25 each
(3) Radiator Top cover - $20 each
(4) Stock MAF - $25 each
(5) Cruise Control Box with cable - $30 each
(1) Set SS rear coils - $30 for the set
(2) Driver side headlight with mount - $25 each
(Many) Caprice Headlights - $15 each
(3) Tail Light Harness - $25 each
(2) Headlight Harness - $40 each
(2) Back window carpet - $25 each
(2) Intake - (1) Stock, (1) Red - $50 each
(2) Set Rear Speaker grills - $25 set
(2) Set rear coat hook passenger lights - $20 per set
These items are Pickup only in Walpole, NH
(2) Dash Pad - $100
(1) Rear Seat Set - $100
(1) Set rough, for repair only door panels - Just the panels - $150
(1) Set good front inner fenders - not perfect, but now rust holes, may have slight surface rust
(1) Driver fender - Black (Rust free)
(1) Passenger fender - Black (Rust free)
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyMon Jun 28, 2010 4:23 pm
You wait till I'm broke to have a clearance sale Mad
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyMon Jun 28, 2010 7:41 pm
Whats the mileage on the steering box
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyMon Jun 28, 2010 8:35 pm
Hmmm... Wonder if the keyless entry is plug and play on the '93..... Cool
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyMon Jun 28, 2010 8:46 pm
I have two, both between 100K and 120K.
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyMon Jun 28, 2010 10:17 pm
does the dual electric fans come with the wiring harness also?? or do u have any harness's???
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyMon Jun 28, 2010 10:18 pm
also how much for the drivers fender??
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyMon Jun 28, 2010 11:22 pm
Yes and I also have the headlight harnesses with the pigtail that plugs into the fan harness!
$75
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyTue Jun 29, 2010 12:08 am
thanks doug
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyTue Jun 29, 2010 12:24 am
Hey Doug, my pal, my bestest buddy Very Happy
Would you happen to have a pair of the splash shields that bolt to the spindles behind the brake rotors? And would those also come with the bolts that hold them on? If you only have complete spindles then I'd be more than willing to pull the shields myself just because I'm such a good friend like that Very Happy
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyTue Jun 29, 2010 10:06 am
no, you already asked me this... I do however still have a set of sway bars with your name on them.... Smile
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyTue Jun 29, 2010 1:38 pm
I'm a pain I know Laughing
I found a lead on the shields so everything's okey dokey on my end. I was actually wondering if you still had those bars. I'll make it a point to grab them from you as soon as I manage to see you again. Schedules have been pretty strange for everyone lately.
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyTue Jun 29, 2010 3:08 pm
No hurry man, trust me.
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyTue Jun 29, 2010 3:24 pm
I'll grab the stuff, and anything else people need shipped down this way, at your grand opening event. Whenever the heck that ends up being Laughing
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyTue Jun 29, 2010 3:28 pm
July 10th Wink
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyTue Jun 29, 2010 5:47 pm
Doug do you have any door spear molding. I need a full set, black is a plus.
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptyFri Jul 02, 2010 11:23 pm
Don't throw out the last of the brake boosters. I'm going to need one at some point in the not too distant future. Mine's full of fluid at the moment.
Did you seperate the aux fuse block (under hood) from the engine wiring harness? If so I could go for a fuse block with the labled cover.
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptySat Jul 03, 2010 9:22 am
I have a black set, one of the front spears has a crack in the back of it, but once installed I don't think it would be noticeable. $50 for the set
I'll have the boosters, no worries.
I do not have the fuse block for under the hood, sorry
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptySat Jul 03, 2010 10:06 am
I need a pair of junked front rotors...
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptySat Jul 03, 2010 10:35 am
My last set left in your truck!
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptySat Jul 03, 2010 10:56 am
LOL! I figured. Damn that Al! Wink
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptySat Jul 03, 2010 7:49 pm
I got a pair.What do you mean when you say JUNKED.
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptySat Jul 03, 2010 8:37 pm
As long as the hat and ABS ring are ok, then that's all I need. Smile
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptySat Jul 03, 2010 8:52 pm
Nope. Sorry Rings are probably OK. But the rest is just a big lump of rust.
PostSubject: Re: Leftovers from 8 Impala part-outs...lots of good stuff left!   Leftovers from 8 Impala part-outs...lots of good stuff left! EmptySat Jul 03, 2010 9:00 pm
That's fine. Send me pics? Smile
» FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc
» LT1 Part outs
» Few parts for sale, went pickin' found some good stuff.
» Anyone got the number for that guy in Tilton(?) from CL for Fleetwood part-outs?
» 95 DCM Impala Part-out
