| | FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc | |
| Subject: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Sat Sep 01, 2012 10:57 pm | |
| Hey guys, just selling off some recently removed parts in hopes of not having to remove them. Well, that and a bunch of other stuff, too. 2.93 posi rear. Drum to drum. Posi was working when removed. $150 ADDCO wagon rear bar with mounting hardware. Mounts to stock LCA's. A couple years old. $125 Stock wagon torque converter. Worked fine, went with a higher stall. $50 Stock upper and lower rear control arms. Nice shape, not rusted, just some light surface rust on uppers. Didn't snap a pic of them all together. You can see one of the lowers in the sway bar pic. $70 Brand new UMI Performance B-body driveshaft safety loop. Black. (center of pic) $50 Trick Flow aluminum rear end cover with carrier preload. Nice. Like new. Installed, but didn't clear wagon gas tank. Never seen oil. Paid $140 at Summit. $100 SOLD!Couple LT1 starters. $40 each Caprice headlight assemblies. $20 each Dark gray Monte Carlo steering wheel with clockspring and wiring, no bag. $50 Older pair of 275/50/15 BFG Drag Radials on 5x5 lug steel wheels. $50 Nice set of 5 9c1 wheels with 3 caps, I think. $100 Pair of 15x7 truck ralleys. $25 Ceramic coated SBC headers. Summit brand. Fit just about everything. Never installed. $150 Old rusty unknown SBC headers, were on a 69 Camaro, so probably fit just about everything. $40 Ruby red Roadmaster LT1 steering wheel with radio controls from Riviera. $40 Bunch of LSx swap stuff: 99 F Body PCM $50 98 F Body engine harness $75 F body exhaust manifolds $50 4th gen fuel tank with pump and sender $50 LS1 intake manifold with fuel rails, no injectors $75 98 LS1 MAF $50 99 T/A Flywheel and clutch $50 500RWHP Money pit. Flashy. Loud. Sophisticated. Causes women's clothing to fall off and tight pants on men. $24,500. All parts are best offer. If you know of something I have that you want, LMK! Thanks!
Last edited by toomanytoyz on Sat Sep 01, 2012 11:27 pm; edited 4 times in total | |
| | | bfurches
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Sat Sep 01, 2012 11:01 pm | |
| If the rear cover is for 8.5 ......DIBS!
Could you double check on the rear radial size?. If 275/60 i will take the pair? U know what brand?
Thanks! | |
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Sat Sep 01, 2012 11:05 pm | |
| - bfurches wrote:
- If the rear cover is for 8.5 ......DIBS!
Thanks! Cover is yours. I will go check the size, but they are BFG's and at least 5 years old. EDIT: They are 275/50's | |
| | | bfurches
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Sat Sep 01, 2012 11:17 pm | |
| are they dry rotted. I dont mind them being old if they are in ok shape...even being a 26" tall...they may be nice to have for testing on the street. Gotta figure out a time I can get to you....next saturday or sunday? | |
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Sat Sep 01, 2012 11:20 pm | |
| - bfurches wrote:
- are they dry rotted. I dont mind them being old if they are in ok shape...even being a 26" tall...they may be nice to have for testing on the street. Gotta figure out a time I can get to you....next saturday or sunday?
I don't think they are dry rotted. I can look more closely if you like. I'm home most days at 330pm. Next weekend could work. I'm also home this weekend. AutoX tomorrow, but will be home in the evening. | |
| | | MASShole9C1
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Sun Sep 02, 2012 12:14 am | |
| Dibs on ceramic summit headers if they are a no bs bolt in item for my 9c1 | |
| | | bfurches
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Sun Sep 02, 2012 1:04 am | |
| This weekend is no good (last weekend to get the car done before the race). Are you going next Saturday? | |
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Sun Sep 02, 2012 6:12 pm | |
| - MASShole9C1 wrote:
- Dibs on ceramic summit headers if they are a no bs bolt in item for my 9c1
They look like they'll fit nice if you trim the frame braces by the rear of the front control arm. | |
| | | bfurches
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Sun Sep 09, 2012 10:38 pm | |
| Hey Bill, I also need a driveshaft for an 8.5" rear car...do you have a spare?
Are you around Saturday or Sunday if I take the ride out twoards you for that rear cover at the least? | |
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Sun Sep 09, 2012 11:19 pm | |
| Sorry, I just tossed my driveshaft a month or so ago.
Next weekend I probably will not be home. Supposed to be going to NJ for my friend's first party at their new house. So, maybe Sunday afternoon. If not, I could always leave it somewhere for ya and you can just come get it. | |
| | | jvette65
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Mon Sep 10, 2012 1:47 pm | |
| Hi Bill, I'd like one of the starters and possibly the truck rally's if not too crusty. -Joe | |
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Mon Sep 10, 2012 9:39 pm | |
| - jvette65 wrote:
- Hi Bill, I'd like one of the starters and possibly the truck rally's if not too crusty. -Joe
You got it. | |
| | | Cadet57
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Fri Sep 14, 2012 5:52 pm | |
| Crovo, how many miles on the wagon rear when it was removed? Any previous work done to it? | |
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Fri Sep 14, 2012 6:31 pm | |
| - Cadet57 wrote:
- Crovo, how many miles on the wagon rear when it was removed? Any previous work done to it?
For all I know, 180K. But it was quiet and the posi still worked. It's not even all that rusty. | |
| | | IMPALADAKID Admin
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Fri Sep 14, 2012 7:43 pm | |
I smell a dibs in 3... 2... 1... | |
| | | Cadet57
| | | | bfurches
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Tue Sep 18, 2012 6:25 pm | |
| - Cadet57 wrote:
- IMPALADAKID wrote:
I smell a dibs in 3... 2... 1... 1
Going up to Crovo's on Sunday Hey Justin...are you really? If you are could you pick up my stuff too? | |
| | | Cadet57
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Tue Sep 18, 2012 6:26 pm | |
If you are could you pick up my stuff too? Yeah, those tires? You still have my #? | |
| | | bfurches
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Tue Sep 18, 2012 6:28 pm | |
Yea, the tires and the rear end cover. Negative on the number.... | |
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Tue Sep 18, 2012 7:19 pm | |
| I like what's happening here. | |
| | | bfurches
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc Tue Sep 18, 2012 7:24 pm | |
- I like what's happening here.
Haha...I hope you don't take it personal Crovo. I would love to come up and meet you in person, but traveling it not my strong suit at the moment lol. | |
| Subject: Re: FS: LOTS OF STUFF! Wagon rear end, ADDCO sway bar, and torque converter, headers, drag radials, LSx swap stuff, etc | |
