94 caprice question EmptyWed Oct 19, 2022 1:27 pm by scot
94 caprice question EmptyTue Oct 18, 2022 8:58 pm by silverfox103
94 caprice question EmptyTue Sep 28, 2021 11:01 pm by silverfox103
94 caprice question EmptyFri Sep 24, 2021 9:53 am by ElKy
94 caprice question EmptySun Sep 19, 2021 6:22 pm by black blur 96
94 caprice question EmptySun Jun 20, 2021 11:37 am by scot
94 caprice question EmptyFri Jun 11, 2021 10:41 am by scot
94 caprice question EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
94 caprice question EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 94 caprice question
7 posters
PostSubject: 94 caprice question   94 caprice question EmptyWed Jun 16, 2010 11:45 pm
hey, my buddy has a 94 caprice with a lt1. on his overflow there are 2 outlets. one used 2 go thru the throttle body, now its bypassed. the other goes 2 the radiator. witch i dont have on my 96 ss. he got a 96 overflow, can he delete the small hose goin 2 the ratiator and cap it??
94 caprice question 90499196
Uploaded with ImageShack.us
PostSubject: Re: 94 caprice question   94 caprice question EmptyThu Jun 17, 2010 12:14 am
If you run an updated radiator without the nipple then you should also get a '96 overflow tank to go with it. I tried capping mine and the cap kept blowing off from the pressure. When I clamped it down tighter it would just rip the cap open.
PostSubject: Re: 94 caprice question   94 caprice question EmptyThu Jun 17, 2010 12:19 am
ok. i wasent thinkin of the pressure in the ratiator. so his best bet would be 2 update 2 a 96 ratiator..
PostSubject: Re: 94 caprice question   94 caprice question EmptyThu Jun 17, 2010 5:15 pm
If the radiator has a nipple then the overflow should too. If the radiator doesn't have one then the overflow shouldn't either. If he did the throttle body bypass then there's still a hose running to the overflow so don't assume you can just unplug it and use that nipple for the radiator because it won't work.
PostSubject: Re: 94 caprice question   94 caprice question EmptyThu Jun 17, 2010 5:29 pm
Just cut the hose back enough to put a bolt into it and clamp it.
PostSubject: Re: 94 caprice question   94 caprice question EmptyThu Jun 17, 2010 7:35 pm
I've got a single line out on the overflow tank. Radialor has the second spot for the hose. Its just capped/clammep off. No issues.
PostSubject: Re: 94 caprice question   94 caprice question EmptyFri Jun 18, 2010 12:44 am
alright cool thanks. thats what were goin 2 try were still having a issue with it overheating. thats what were trying to figure out now
PostSubject: Re: 94 caprice question   94 caprice question EmptyFri Jun 18, 2010 2:06 am
Where's the car with the issues? Maybe someone could swing by and give a fresh set of eyes. I know I've figured out the lt1 cooling system pretty well over the years Laughing
PostSubject: Re: 94 caprice question   94 caprice question EmptyFri Jun 18, 2010 10:09 am
the car is at his house in bridgewater on rt.18.
PostSubject: Re: 94 caprice question   94 caprice question EmptyFri Jun 18, 2010 2:32 pm
I used to live in Bridgewater Laughing Got a degree there too Wink
If either of you guys need a bit of a hand or a fresh set of eyes to look at something then drop me a line. I'm out that way a fair bit.
PostSubject: Re: 94 caprice question   94 caprice question EmptySat Jun 19, 2010 10:10 am
ya deff. pm me if ur in the area this weekend iam sure well be workin on it. he has no problem with u stopping by.. nothin wrong with a third opinion
PostSubject: Re: 94 caprice question   94 caprice question EmptySat Jun 19, 2010 11:57 am
I was just down that way this morning. Went to Woods and Chuckrans on a parts hunt. I would have stopped by but I don't know where you guys are Laughing
PostSubject: Re: 94 caprice question   94 caprice question EmptySat Jun 19, 2010 3:01 pm
right on 18 by peaceful meadows. give me a ring if ur around sunday. we'll be in his garage
PostSubject: Re: 94 caprice question   94 caprice question EmptyMon Jun 28, 2010 8:57 pm
So is that one Mike's? Or Mike's? Wink
Glad you got that phucker on the road! Woot! Now it's time for a ROAD TRIP!!!!!! cheers
PostSubject: Re: 94 caprice question   94 caprice question EmptyMon Jun 28, 2010 10:12 pm
ya he'll be bringin it 2 the south shore meet in easton on the 18th. but before then i need 2 paint his impala trunk lip and we need 2 clean it. its been slowly gettin worked on and sitting in the garage for 2-3 years
PostSubject: Re: 94 caprice question   94 caprice question EmptyTue Jul 06, 2010 10:38 am
alright. we got the bugs out of the caprice about a week ago. he was headin home from work the other day and the temp started 2 climb again.and the upper hose is smokin hot and the lower half of the lower hose is cold. also the pass. side of the radiator is cold. could it be a clogged radiator? i topped off the coolent and blead the system again but didnt get much air we are lost now.. Shocked
PostSubject: Re: 94 caprice question   94 caprice question EmptyTue Jul 06, 2010 10:41 am
Thermostat or waterpump?
PostSubject: Re: 94 caprice question   94 caprice question EmptyTue Jul 06, 2010 10:43 am
t stat is a 1 week old 160 stat and the waterpump is about 50 miles on it..
PostSubject: Re: 94 caprice question   94 caprice question EmptyTue Jul 06, 2010 11:02 am
sounds like the thermostat isnt opening...
Is the line just HOT or is it filled with pressure (if you squeeze it with a rag).
Sure sounds like the t-stat isnt popping open an allowing the colder coolant to pass through.
PostSubject: Re: 94 caprice question   94 caprice question EmptyTue Jul 06, 2010 11:12 am
theres deff pressure in the upper hose. and there is coolent comin out the bleeder screw on the tstat housing. the tstat is a mr gasket 160 stat. and for the last week the cars been runnin at 150 it has a aftermarket auto meter gauge so thats workin correct
PostSubject: Re: 94 caprice question   94 caprice question EmptyTue Jul 06, 2010 1:12 pm
You sure it's a gen2 thermostat? I've heard tell of folks sticking a regular chevy 350 t-stat in their engine and having some interesting issues.
Your discription is exactly what happened with my car when the t-stat failed. I could drive it about 10 miles and the temp would reach the red and I'd have to pull over and wait 20 minutes before I could drive it another 5. One hose was too hot to touch and the other was luke warm from the engine heat.
I'd test the t-stat (hot water in a pan trick) and back flush the radiator and hope for the best.
PostSubject: Re: 94 caprice question   94 caprice question EmptyTue Jul 06, 2010 2:05 pm
I have had horrible luck with those mr gasket high flow t-stats. throw that thing in the trash and pop a regular stant in her.
PostSubject: Re: 94 caprice question   94 caprice question EmptyTue Jul 06, 2010 2:14 pm
its weird cause we got both stats at the same time. i have mine in my 96 ss and it runs so cool all the time. and his just started acting up after a week..
PostSubject: Re: 94 caprice question   94 caprice question EmptyTue Jul 06, 2010 3:44 pm
How hot is the car running? Is it straight up overheating or is it just running warmer (say 190-200)?
Pop the t-stat out and inspect it. I have seen the inner o-ring style seal come apart and jam the stat closed.
If you are getting super hot within a few minutes and the upper hose is hot as hell and feels like its ready to burst, by guess would be that the t stat isnt opening.
Another thing you could do....with the car cooled down, take off the rad cap, start the car up and let it reach low operating temp and see if the coolant is moving across the inside of the core. (obviously dont get too close, and as the car builds temp a little overflow will most likely slosh out, but there wont be any extreme pressure such as cracking the cap at 200* lol).
PostSubject: Re: 94 caprice question   94 caprice question EmptyTue Jul 06, 2010 6:07 pm
does Mr Gasket make an LT1 thermostat ?
94 caprice question Tstat
PostSubject: Re: 94 caprice question   94 caprice question EmptyWed Jul 07, 2010 10:12 am
we pulled the tstat last night and it seemed like it wasent working right so we put it back 2gether without the tstat 2 see if thats what it was and it was running alot cooler..
PostSubject: Re: 94 caprice question   94 caprice question EmptyWed Jul 07, 2010 10:31 am
Remember that mr gasket is just like bosch and a few other chinese companies. They make some nice parts and some not so nice parts. When in doubt just buy ac-delco or duralast gold
94 caprice question
» Question on BOX CAPRICE rear end / spindles
» hypothetical question about 91/95 and a 96
» L99 performance question
» Bare top FWB question
» Q-jet question
