My temp gauge usually reads straight up. The scanner says the engine is at 180. My primary fan relay doesn't kick in until I'm almost at redline (215?) so I've installed a set of auxiliary switches to manually pull in the primary and secondary fan relays. Only problem is, after I use the auxiliary switches my check engine light is on for a few days.
