| Author | Message |
 | Subject: LSX/4L80E swap? Sun Feb 21, 2010 12:39 pm | |
| Anyone here done one? Care to discuss? I am thinking about it with a LQ4/4L60E or 4L80E combo.
http://www.impalassforum.com/vBulletin/showthread.php?t=228454 |
JRS9C1
Posts: 434 Join date: 2009-01-20 Age: 23 Location: Bethel ME
 | Subject: Re: LSX/4L80E swap? Sun Feb 21, 2010 12:45 pm | |
| If you can afford it, do it. I would if I could. Although I would run as far away as you can from the 4L60E in the process...4L80E or 6 speed is the only way. |
Posts: 2301 Join date: 2009-02-22 Age: 31 Location: Mansfield, Ma
 | Subject: Re: LSX/4L80E swap? Sun Feb 21, 2010 12:48 pm | |
| You can't afford it I researched it for a few years and came to the conclussion that the best option for that Caprice is a LQ4/4l80e combo with the matching pcm and wiring harness. Also use a set of the L92 heads as well as the ls6 style car intake, which became the standard ls intake after I think 2002. Use the fuel filter/regulator from a certain year (forget which) Corvette and that solves the problem of the return line not being present on those intakes. The install kit and headers are avaialble through S&P if I remember right. By the way, you'll blow up the rear-end if you do it all right  |
Posts: 644 Join date: 2009-02-25 Age: 55 Location: Nashua NH.
 | Subject: Re: LSX/4L80E swap? Sun Feb 21, 2010 12:52 pm | |
| Those magnachargers can up the power by over 150 horses on an lq4 from the documentation I've seen. There's a Vette I see all the time at the local shows that has one. |
 | Subject: Re: LSX/4L80E swap? Sun Feb 21, 2010 1:06 pm | |
| I would like to do a stock LQ4 ith LS1 intake and caddy oil pan. Not to sure on wiring, headers, and accessories, but I am learning. |
 | Subject: Re: LSX/4L80E swap? Sun Feb 21, 2010 1:14 pm | |
| You'll want the headers from the same company as the mounts. They are designed as a package and mix-matching them will throw off the fitment of everything. I was going to start by putting in a 4l80 using a clear-image crossmember and then use that as the alignment point for the engine. That way the trans back would be properly aligned and it would force the engine into the correct position for the mounts to be installed. That method may cause interference with the firewall though once the engine is in place  |
 | Subject: Re: LSX/4L80E swap? Sun Feb 21, 2010 1:21 pm | |
| there is this advanced auto in Lowell that has connections with junk yards across the country,we got an AWD Trans for a mountaineer for $500 and 1 year warranty |
Posts: 5924 Join date: 2009-01-20 Age: 36 Location: Sandown, NH USA
 | Subject: Re: LSX/4L80E swap? Sun Feb 21, 2010 2:16 pm | |
| If I stick with the B's, my next motor build will most definately be an LQ4 and T56. So you know my vote.  _________________ Bill "The Verb" Crovo - Resident Car Slut 95 WB4 -The Toasted Marshmallow- Quick and Fat, sorta like it's owner... 00 Sierra 2500 ECSB -The Big Slut- H2's & 33's, TB crank, CAI, Magnaflow, Cowl'd, etc... 95 9C1 -Project AutoX Slut- MAB!!<--Finally!! West coast car, rust free! T56 and suspension mods to come! 94 Fleetwood -The Ill Brougham- Praise the Lowered! Satin Black, red wheels, whitewalls, glasspacks. 'Nuff said. American Ricerwww.badassofne.net "Ooooh! Look! Something shiny!"LOWER IT!!!  |
 | Subject: Re: LSX/4L80E swap? Sun Feb 21, 2010 2:39 pm | |
| | toomanytoyz wrote: | | If I stick with the B's |
What you takin bout Willis? You thinking of hanging it up? |
Posts: 1828 Join date: 2009-01-21 Age: 26 Location: NH
 | Subject: Re: LSX/4L80E swap? Sun Feb 21, 2010 6:11 pm | |
| 6.0 LQ4 GMC / Chevy motor - $300 This motor spun a cam bearing with 99,000 miles on it http://nh.craigslist.org/pts/1611671292.html |
Posts: 1222 Join date: 2009-01-21 Age: 50 Location: Rumford, Maine
 | Subject: Re: LSX/4L80E swap? Sun Feb 21, 2010 11:45 pm | |
| Now youv'e guys have done it! Billy Mac mentions it, Crovo says T-56, now ya got me thinkin..... dammit! lol. |
