 t56 swap
PostSubject: t56 swap   Mon Sep 06, 2010 9:18 am
iam thinking of doing the t56 swap this winter on my 96. how much of a pain is it to set up? and is it worth it? tring to figure out if i want to do it..
PostSubject: Re: t56 swap   Mon Sep 06, 2010 9:30 am
Bill Crovo has done it twice, and is the man to talk too. Ron "Iceman" as well as Jason "jayss" have done it too.
PostSubject: Re: t56 swap   Mon Sep 06, 2010 10:11 am
isnt your car on craigslist right now??
Anywho, ill be doing this swap over winter, as my trans. is toast!
PostSubject: Re: t56 swap   Mon Sep 06, 2010 11:01 am
You need the F2B kit, the tranny and pedals and all and a weekend. Smile
PostSubject: Re: t56 swap   Mon Sep 06, 2010 11:39 am
hey billy, question. When i do the 6speed, how soon after will i need gears& driveshaft? could i put around for few weeks on my one-leg 293s or will the car not even move lol
PostSubject: Re: t56 swap   Mon Sep 06, 2010 11:41 am
You could drive it, but I wouldn't do it for long. It'll be doggy, and you'll probably wear out the clutch. You may not even need a driveshaft...
PostSubject: Re: t56 swap   Mon Sep 06, 2010 11:48 am
hmm.. i thought i read that if you go with 373s or more you NEED a driveshaft.. ill be doing 410s at the minimum
PostSubject: Re: t56 swap   Mon Sep 06, 2010 1:20 pm
I have everything but a driveshaft to do mine. Just need time now.
PostSubject: Re: t56 swap   Mon Sep 06, 2010 4:22 pm
i drove jay ss's white woody with the t56 and the 2:93's it was fine,. BUT he had a heavy flywheel, and an organic disc, AND the motor was tuned right,. you could roll away at idle just fine,. nice car to drive,..its all in the tuning with a 6spd,.
Nick
PostSubject: Re: t56 swap   Mon Sep 06, 2010 6:07 pm
Yeah, some cars can get by with 4.10's and the stock shaft without a vibration. If it were me, I'd save the $400+ and try it without a new shaft first. Then if I needed one, I'd get one.
FWIW, my Fleetwood didn't need one with 4.56's and 26" tires. Smile
t56 swap
» TAG SWAP - LADIES
» Swap Ideas for 2010!!
» SWAP IDEAS!!
» CADDY RADIO SWAP
