| Transmission temp sensor help.. | |
| Subject: Transmission temp sensor help.. Wed Mar 07, 2018 5:48 pm | |
| Replacing trans lines on my caddy..... has anyone removed the trans temp sensor and block from the lines without any issues?
I’d think its not needed for a daily driver but then again it was designed to be there from the factory for a daily driven vehicle.. | |
| Subject: Re: Transmission temp sensor help.. Thu Mar 08, 2018 3:22 pm | |
| Don’t think you’re gonna get an answer...... | |
| Oh yeah? And why is that? | |
| Bc this site is a ghost town..... it’s just us here right now | |
| Subject: Re: Transmission temp sensor help.. Thu Mar 08, 2018 3:23 pm | |
| Wow you’re right!!!!
Let’s take our clothes off!!!!!!!!!!!!!! | |
| Subject: Re: Transmission temp sensor help.. Thu Mar 08, 2018 9:48 pm | |
| Never knew it had one.
Ask over at the Impala forum or Wagon forum. Joel the transmission guy should be able to answer your question.
Tom | |
| Subject: Re: Transmission temp sensor help.. Thu Mar 08, 2018 10:16 pm | |
| Thanks Tom. At least that’s what I think this thing is. It’s a small box with a one wire sensor that s coming off the trans cooler lines. The trans lines tap into it. It’s in a ridiculous spot so I don’t want to reinstall if I don’t have to. | |
| Subject: Re: Transmission temp sensor help.. Sat Mar 10, 2018 2:18 pm | |
| If you mean the brass type block on the trans lines it’s the TC over temp switch. Locks the converter earlier I guess when the PCM is told the trans is super hot. Without it, the pcm just wont get that signal. Plenty of people have deleted it. I don’t even think it’s connected on mine. I don’t think L99 cars came with one either. | |
| Subject: Re: Transmission temp sensor help.. Sun Mar 11, 2018 2:41 pm | |
| Thanks man! Deleted it is then! | |
| Subject: Re: Transmission temp sensor help.. | |
