 Need 160 degree stat & fan temp lowered on OBD1 PCM
PostSubject: Need 160 degree stat & fan temp lowered on OBD1 PCM   Mon Jul 16, 2012 9:26 am
If somebody can hook me up, that would be awesome! It all started with me swapping the hi/low rad vent tubes after my new WP Swap, couldn't understand why it was overheating, duh!
PostSubject: Re: Need 160 degree stat & fan temp lowered on OBD1 PCM   Tue Jul 17, 2012 2:21 pm
24 views, anybody?
jamsal
PostSubject: Fan Temp on OBD1   Tue Jul 17, 2012 3:22 pm
"Jet" has a fan switch for the Camaro that I used. It Turns the the Fans on at 160. It comes complete. You just have to remove the square plug on the drivers side head area to install the switch. It wasn't that much money either. You could also used the Hypertech programmer to change the fan temp.
Not sure if thats what you're looking for.
PostSubject: Re: Need 160 degree stat & fan temp lowered on OBD1 PCM   Tue Jul 17, 2012 9:35 pm
I can reprogram the PCM for you.
You're on your own with the thermostat.
PostSubject: Re: Need 160 degree stat & fan temp lowered on OBD1 PCM   Tue Jul 17, 2012 10:15 pm
What are your hours? lol!
PostSubject: Re: Need 160 degree stat & fan temp lowered on OBD1 PCM   Wed Jul 18, 2012 12:39 am
Are you getting anything from Al? I don't live too far from him.
PostSubject: Re: Need 160 degree stat & fan temp lowered on OBD1 PCM   Wed Jul 18, 2012 7:29 am
Me too. Smile
(just saw this)
