Starting the process of cleaning out my garage and have items that need a good home!
6/14/15 UPDATE
- New (package open) DEI Spark Plug Wire Protection: 8 Cylinder Kit, Red 6" - $25
SOLD- New in packaging Lokar TC-1000TP Throttle Cable - $25
SOLD- New in packaging Lokar ACA-1800 Adjustable Billet Column Arm Kit TH350/400/700 - $25
-LT1 Block: Came with my '94 Camaro roller, and is bare block - would need to obviously be cleaned and rebuilt. Have the crankshaft and pistons to go with it - $150
-4L60E: originally from a '94 Firebird, installed in my S10 Blazer with LT1, had a transgo shift kit, corvette servo, and Summit extra capacity pan. When last used it only had 1st and 2nd gear and would need to rebuilt. The pan itself retails for over $100. - $150
TRANSMISSION SOLD, STILL HAVE PAN-Yank SS3600 Torque Converter: had this installed for a season and is a very stout converter - $200
SOLD-B&M Transmission Cooler: Just the cooler, don't have the hoses for it - $30
-Camaro Radiator & Dual E-Fans: also from the Camaro roller - $75
-'01 Blazer Rear End: 8.5, 3.42, G80 differential - $200
SOLD- Set of 4 Wheels - US Wheel 84 with 225/75r15 rubber. 5 x 4 3/4 Spacing (had installed on 2wd S10) - $125
SOLD-Blazer overhead console - $50
I have some other Camaro/LT1 items if you are looking for something specific (trans crossmember, driveshaft, few odds and ends from the engine). Also have Impala SS Seats that never sold and are sitting in my storage space. Have pictures of most items, let me know if you are interested. All parts are located in Kingston, NH.
Edit for pictures
