Building Heads/Cam LT1 EmptyWed Oct 19, 2022 1:27 pm by scot
Building Heads/Cam LT1 EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Building Heads/Cam LT1 EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Building Heads/Cam LT1 EmptyFri Sep 24, 2021 9:53 am by ElKy
Building Heads/Cam LT1 EmptySun Sep 19, 2021 6:22 pm by black blur 96
Building Heads/Cam LT1 EmptySun Jun 20, 2021 11:37 am by scot
Building Heads/Cam LT1 EmptyFri Jun 11, 2021 10:41 am by scot
Building Heads/Cam LT1 EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Building Heads/Cam LT1 EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
6 posters
PostSubject: Building Heads/Cam LT1   Building Heads/Cam LT1 EmptyThu Feb 26, 2015 10:16 pm
I've been building a motor for a guy down here in Orlando. He originally wanted to do a cam.. then heads... but with 160k+ I didn't want to trust the bottom end. He brought the car here I yanked the motor and ended up rebuilding it... on a budget. Stock 350 bottom end reused rotating assembly. Basic machine work light hone, crank polish, new bearings and rings. Motor was in decent shape. Rod bearings were toast. It ran very well and made no noises before.
Advanced Induction 190cc heads, CC305 cam.
Building Heads/Cam LT1 10847889_10152517022828947_4902402297942363028_n
Building Heads/Cam LT1 11017008_10152716593583947_5595636555783367784_n
Building Heads/Cam LT1 1450949_10152656408913947_4163805588502429886_n
Building Heads/Cam LT1 10420174_10152539998368947_5723754508430637883_n
Building Heads/Cam LT1 1506659_10152716628268947_8529108762193527382_n
Building Heads/Cam LT1 10394020_10152567956438947_4150729531289256817_n
Building Heads/Cam LT1 10994340_10152716592798947_7428206819585444280_n
Building Heads/Cam LT1 11037312_10152716594293947_2139564406930738576_n
Building Heads/Cam LT1 11016840_10152716594038947_8652404093425456202_n
Building Heads/Cam LT1 10350528_10152716593723947_5086176693835186075_n
Mock up. top end not mounted just sitting on the block, heads were on backwards.
Building Heads/Cam LT1 11021104_10152716627938947_5475310788321540516_n
Building Heads/Cam LT1 10999088_10152716630463947_6027654457765348128_n
Building Heads/Cam LT1 18314_10152716630533947_2992599437143645825_n
Assembly will be completed this weekend and maybe I'll drop it in the car.
PostSubject: Re: Building Heads/Cam LT1   Building Heads/Cam LT1 EmptyFri Feb 27, 2015 6:19 am
Looks great.
SOooo nice to start fresh isnt it?
Arrow
Over the valve cover wires can get tricky....depending on whats taking the exhaust outta there
PostSubject: Re: Building Heads/Cam LT1   Building Heads/Cam LT1 EmptyFri Feb 27, 2015 7:26 am
There are going to be longtube after burners. I have a 30ft roll of wire and my own ends so I will cut them so there is plenty of space.
PostSubject: Re: Building Heads/Cam LT1   Building Heads/Cam LT1 EmptyFri Feb 27, 2015 10:11 am
I can take a pic of Matts car if you want to know what you'll be dealing with for room
As I remember #5 is tough....I'm sure you'll be fine
You still looking for the seatbelt?
REALLY sorry I havent been able to do that simple task
I'll tell you my tale of woe someday when the dust settles
PostSubject: Re: Building Heads/Cam LT1   Building Heads/Cam LT1 EmptyFri Feb 27, 2015 4:25 pm
Excellent! That cam is pretty popular, I see. I plan to use the LT1 out of my rms for something. You've got me nervous about not opening up the engine and inspecting the inside of it.
PostSubject: Re: Building Heads/Cam LT1   Building Heads/Cam LT1 EmptyMon Mar 02, 2015 6:14 pm
Brian if the motor is working and you don't plan on more HP then leave it alone.
Painted a few parts to make the motor look nice.
Building Heads/Cam LT1 10991284_10152723738658947_2027728602295739860_n
Building Heads/Cam LT1 16192_10152723740408947_3524280549530597661_n
You can see at the bottom of the water pump cover, one of the tabs was broken off. I filed it away and I think it looks better without it.
Building Heads/Cam LT1 11038866_10152723739453947_8555395124170657420_n
Building Heads/Cam LT1 984281_10152723741223947_4829390950998976178_n
Building Heads/Cam LT1 10689501_10152723743348947_6115773135329287777_n
Building Heads/Cam LT1 10421310_10152723744408947_341501293050433141_n
Building Heads/Cam LT1 10984063_10152723745433947_3222251634703650089_n
Building Heads/Cam LT1 10988276_10152723745848947_6524285133203951350_n
Building Heads/Cam LT1 13611_10152723746078947_8710111290090499199_n
Building Heads/Cam LT1 10384202_10152723746803947_1368359647708514376_n
Building Heads/Cam LT1 11021253_10152723747508947_233363235352893000_n
Might try to drop it in tonight. I need to measure pushrod length and prime the oil pump before installing the intake.
PostSubject: Re: Building Heads/Cam LT1   Building Heads/Cam LT1 EmptyMon Mar 02, 2015 7:13 pm
Arrow
PostSubject: Re: Building Heads/Cam LT1   Building Heads/Cam LT1 EmptyMon Mar 02, 2015 7:51 pm
Sweet! That's pretty close to my motor. I have the CC306 and similar heads in a stock bottom-end 350. And it put down 340 to the wheels through a t56. That's over 400 at the flywheel. You should see similar numbers with a good tune.
Good stuff. Smile
PostSubject: Re: Building Heads/Cam LT1   Building Heads/Cam LT1 EmptyMon Mar 09, 2015 2:06 am
aaaand its in. Still have to bolt up trans and connect wiring. Waiting on computer, 30lb injectors and correct length pushrods changed for proper valve train geometry.
Building Heads/Cam LT1 11047924_10152736251638947_6384435828486490092_n
Building Heads/Cam LT1 11050745_10152736251523947_7634932988315630339_n
Building Heads/Cam LT1 10429840_10152736250798947_8046312722955190524_n
Building Heads/Cam LT1 20715_10152736247928947_7776385753189097202_n
Building Heads/Cam LT1 11041733_10152736248148947_2559367670442786686_n
Building Heads/Cam LT1 20522_10152736248218947_579486884554219967_n
Building Heads/Cam LT1 11008410_10206423652456755_2463726455816997417_n
PostSubject: Re: Building Heads/Cam LT1   Building Heads/Cam LT1 EmptyMon Mar 09, 2015 2:39 am
How much more length did you need on the push rods?
PostSubject: Re: Building Heads/Cam LT1   Building Heads/Cam LT1 EmptyMon Mar 09, 2015 11:36 pm
Stock length is 7.2 I needed 7.1. Every motor will be different after being machined. Heads were machined also. So I lost height.
PostSubject: Re: Building Heads/Cam LT1   Building Heads/Cam LT1 EmptyWed Mar 11, 2015 2:53 pm
Pretty!
PostSubject: Re: Building Heads/Cam LT1   Building Heads/Cam LT1 EmptyMon Apr 06, 2015 12:20 am
Car is up and running. Built transmission and converter are going in it today.
Here is the car in Daytona last weekend, me behind the wheel.
Building Heads/Cam LT1 11046704_10206588012365650_4447566095577677844_n
Building Heads/Cam LT1 11075155_10206588012765660_5911082241903727854_n
PostSubject: Re: Building Heads/Cam LT1   Building Heads/Cam LT1 EmptyMon Apr 06, 2015 12:16 pm
Hope the owner was the guy holding the camera.....
If I had someone doing work to my car and found them beating the snot out of it in the street I'd be scraping prostate off my steel toed boots
PostSubject: Re: Building Heads/Cam LT1   Building Heads/Cam LT1 EmptyTue Apr 07, 2015 12:25 am
Unfortunately he left this bbody event earlier in the night and was not filming but he did see the video and loved it.
» Building an engine
» Iron Heads
» building a cluster....any interest?
» LE2 heads and cam
» Stock Heads
