WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptyWed Oct 19, 2022 1:27 pm by scot
WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptyTue Oct 18, 2022 8:58 pm by silverfox103
WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptyTue Sep 28, 2021 11:01 pm by silverfox103
WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptyFri Sep 24, 2021 9:53 am by ElKy
WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptySun Sep 19, 2021 6:22 pm by black blur 96
WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptySun Jun 20, 2021 11:37 am by scot
WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptyFri Jun 11, 2021 10:41 am by scot
WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
3 posters
lynol
lynol
PostSubject: WTB: '92-'93 HEATER HOSES (Quick-Connect type)   WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptyMon Sep 22, 2014 2:48 pm
Hi folks. I'm in need of a set of heater hoses for my '92 OCC. The ones I need would be from a '92 or '93 Caprice wagon or sedan, '92 or '93 Roadmaster wagon, or a '93 Roadmaster sedan. All '91 B-bodies and the '92 RMS setup uses a bypass valve, and as I just found out, one of the heater core pipes is a different size on the '92-'93! It may be possible that only some early '92 RMS's use the hoses with the bypass, I just know I can't use anything with a bypass in it. What I need is the setup that is two separate hoses, with an inline restrictor, and with Quick-Connect ends on the heater core attaching side. Post here or PM me if you've got 'em. Thanks guys!
-Lynol
PostSubject: Re: WTB: '92-'93 HEATER HOSES (Quick-Connect type)   WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptyMon Sep 22, 2014 8:38 pm
Like these hoses?
http://m.ebay.com/itm/390434919562?nav=SEARCH
I bet Justin has some.
PostSubject: Re: WTB: '92-'93 HEATER HOSES (Quick-Connect type)   WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptyTue Sep 23, 2014 7:57 am
Why not buy new hoses?
lynol
lynol
PostSubject: Re: WTB: '92-'93 HEATER HOSES (Quick-Connect type)   WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptyTue Sep 23, 2014 9:50 am
Because I don't want to spend $151.16 plus tax. Just called the dealer and got the prices for both those hoses.
lynol
lynol
PostSubject: Re: WTB: '92-'93 HEATER HOSES (Quick-Connect type)   WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptyTue Sep 23, 2014 9:57 am
Like these hoses?
No, those are the '94-'96 style hoses. Way different. Here's a pic of one of the ones I need. This is the hose that goes from the rad to the heater core in the '92-'93s
WTB: '92-'93 HEATER HOSES (Quick-Connect type) $%28KGrHqFHJEgE8oY,p!UjBPdMbOTCug~~60_57
PostSubject: Re: WTB: '92-'93 HEATER HOSES (Quick-Connect type)   WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptyTue Sep 23, 2014 11:47 am
I understand.
Found these 2 on ebay. Only the feed from the engine, there were a bunch of molded hoses that might fit for the return.
http://www.ebay.com/itm/NOS-1992-1993-Chevrolet-Impala-SS-Heater-Control-Hose-10165022-/281073988504?pt=Vintage_Car_Truck_Parts_Accessories&fits=Year%3A1992|Model%3ACaprice&hash=item417150b398&vxp=mtr
http://www.ebay.com/itm/Heater-Hose-Assy-1992-93-Caprice-Black-Rubber-10165021-Roadmaster-Custom-Cruiser-/370634390181?pt=Motors_Car_Truck_Parts_Accessories&hash=item564b87faa5&vxp=mtr
For the return, there is a 1992 at my local pick n pull. I could grab that return hose and then you could rebuild it with a new hose and connector? Any shop that can crimp AC lines should be able to do the same with the heater hose.
lynol
lynol
PostSubject: Re: WTB: '92-'93 HEATER HOSES (Quick-Connect type)   WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptyTue Sep 23, 2014 1:50 pm
I understand.
I'll see what I can turn up. The dealer wants $97 for the hose that goes from the engine to the core, and $53 for the return to the radiator. Go figure the short hose is almost double the price. Ideally I would like to find a clean used set, and just plug it in. The rubber on mine was in good shape at 20 years old when I broke the connector off it, so I'd be fine with a used set. I never drive the OCC in cold weather, so I never bothered to fix it until now, and I found the '91 9C1 set I had grabbed from like 2 years ago won't fit. Just think how many times I've passed up correct sets in the yard since then... ugh...
PostSubject: Re: WTB: '92-'93 HEATER HOSES (Quick-Connect type)   WTB: '92-'93 HEATER HOSES (Quick-Connect type) EmptyTue Sep 23, 2014 10:50 pm
lynol wrote:
Like these hoses?
Oooops. My bad. I was looking at the. 92-93 hoses then clicked on these and for whatever reason pasted THIS link. I hope you find what you're looking for without a second mortgage.
» Anybody looking for LT1 9C1 hoses?
» F/S NIB heater core
» what size is the washer nozzle hoses?
» WTB: Looking for correct hose clamps for green 9C1 hoses
» Heater core?
