» Anybody out there?
exhaust manifold heat sheld EmptyToday at 10:41 am by BostonChevy
exhaust manifold heat sheld EmptyWed Oct 19, 2022 1:27 pm by scot
exhaust manifold heat sheld EmptyTue Oct 18, 2022 8:58 pm by silverfox103
exhaust manifold heat sheld EmptyTue Sep 28, 2021 11:01 pm by silverfox103
exhaust manifold heat sheld EmptyFri Sep 24, 2021 9:53 am by ElKy
exhaust manifold heat sheld EmptySun Sep 19, 2021 6:22 pm by black blur 96
exhaust manifold heat sheld EmptySun Jun 20, 2021 11:37 am by scot
exhaust manifold heat sheld EmptyFri Jun 11, 2021 10:41 am by scot
exhaust manifold heat sheld EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
May 2024
3 posters
PostSubject: exhaust manifold heat sheld   exhaust manifold heat sheld EmptyWed Jan 25, 2012 5:21 am
Was wondering if the stock heat sheilds on the manifolds can be removed and put back on? without removing the manifolds would be great. Kinda got a plan for the shields.
PostSubject: Re: exhaust manifold heat sheld   exhaust manifold heat sheld EmptyWed Jan 25, 2012 7:20 am
I believe they are tack welded together over the cast iron.
PostSubject: Re: exhaust manifold heat sheld   exhaust manifold heat sheld EmptyWed Jan 25, 2012 7:21 am
so if I pop the tack welds it should separate.
PostSubject: Re: exhaust manifold heat sheld   exhaust manifold heat sheld EmptyWed Jan 25, 2012 7:28 am
Yea it should slide off you might have to take a few other items off that are in the way, (it's been a while)
PostSubject: Re: exhaust manifold heat sheld   exhaust manifold heat sheld EmptyWed Jan 25, 2012 1:36 pm
cool thanks man. lets see how it goes just finally got the heat running nice and hot. figures to is 50 out.
Bull
Bull
PostSubject: Re: exhaust manifold heat sheld   exhaust manifold heat sheld EmptyWed Jul 24, 2013 11:50 pm
Yeah, the thread is old but I found it in a forum search for exhaust manifold bolts.
The heat shield are folder around the manifolds and tacked to themselves, but they are actually secured to the manifolds with little steel pins.
» Exhaust manifold bolt fix
» WANTED DR side Exhaust manifold
» Passenger Side Exhaust manifold needed
» 95 FWB HVAC question- no heat, no A/C
» heat
