» C10: Before and After
95 FWB HVAC question- no heat, no A/C EmptySun Jun 02, 2019 3:01 pm by MalibuSSwagon
95 FWB HVAC question- no heat, no A/C EmptySat Mar 16, 2019 8:49 am by boojum
» Mass refugee now in Pa
95 FWB HVAC question- no heat, no A/C EmptyTue Jan 22, 2019 8:46 am by MASShole9C1
95 FWB HVAC question- no heat, no A/C EmptyTue Jan 22, 2019 12:03 am by boojum
» 1996 DGM RMW
95 FWB HVAC question- no heat, no A/C EmptyFri Jan 18, 2019 12:00 pm by Gorillabiter
95 FWB HVAC question- no heat, no A/C EmptyWed Oct 31, 2018 7:53 pm by Ironfistdog
» Roundup pics?
95 FWB HVAC question- no heat, no A/C EmptyTue Oct 23, 2018 12:41 pm by silverfox103
95 FWB HVAC question- no heat, no A/C EmptyThu Oct 18, 2018 7:51 pm by silverfox103
» Looking for exhaust part
95 FWB HVAC question- no heat, no A/C EmptyTue Oct 16, 2018 12:37 pm by fatvet
June 2019
3456789
10111213141516
17181920212223
24252627282930
Share
FUN-9C1
FUN-9C1
PostSubject: 95 FWB HVAC question- no heat, no A/C   95 FWB HVAC question- no heat, no A/C EmptySun Nov 17, 2013 1:00 pm
I'm 95% sure I used the AC in my FWB at some point this summer and it worked fine. Toward the end of the summer I went to use it and it was no less than ambient temp. I figured it lost the charge, but then recently I went to use the heat, and no heat! The fan and everything works, just no temp control. I know the heater core is not clogged because I just flushed it out (and the block) right after I bought it this spring. I can't think of anything else that would cause no heat. My t-stat is good, eng gets to operating temp, coolant is full.
Following the instructions in the FSM, I went into the HVAC diagnostics and in the -02 pointer, it displayed 126, which I THINK means HVAC DTC 26, which is "Serial Data Communication". The first step is to check pin "M" at the DLC (the comm port under the dash). I cannot find anything that shows which pin is which. In the next steps, it mentions "terminal D12 at the HVAC control center". Anyone know how I find which one is that one? Am I on the right track? If I KNEW it was the HVAC module itself, I would probably replace it with a RM one, but looking at the FSM it looks more likely to be short somewhere. I sure hope that is not the case! I do have a known good HVAC module in my RMW. How hard would that be to swap temporarily?
Any help with that or any other ideas would be appreciated! THanks!
PostSubject: Re: 95 FWB HVAC question- no heat, no A/C   95 FWB HVAC question- no heat, no A/C EmptySun Nov 17, 2013 1:40 pm
My RMW shows 126 too, but everything seems to work. Sounds like the blend door isn't moving to me. Start by disconnecting the battery for a few minutes, then after you reconnect it turn the ignition to run. The climate control will recalibrate itself so don't don't touch it for about 30 seconds. The blower will come on when it's done. During the calibration you should hear the blend door moving.
Try that out and see if it fixes it.
FUN-9C1
FUN-9C1
PostSubject: Re: 95 FWB HVAC question- no heat, no A/C   95 FWB HVAC question- no heat, no A/C EmptySun Nov 17, 2013 9:17 pm
Thanks for the suggestion. I did the procedure you said, hopefully tomorrow I can get a chance to start 'er up and try the heat. I did hear something operate after turning the key on, I assume that was the door, then the fan came on like you said it would. It'd be awesome if it were that easy! I'll let you know after I try it.
PostSubject: Re: 95 FWB HVAC question- no heat, no A/C   95 FWB HVAC question- no heat, no A/C EmptyMon Nov 18, 2013 9:55 am
If that doesn't work, try swapping in the roadie head unit. Plugs right in, so for testing purposes, it's simple. It'll take a few minutes longer to modify it to fit your dash, though.
95 FWB HVAC question- no heat, no A/C ToastedSig_zps6c195980
FUN-9C1
FUN-9C1
PostSubject: Re: 95 FWB HVAC question- no heat, no A/C   95 FWB HVAC question- no heat, no A/C EmptyTue Nov 19, 2013 5:29 pm
Well Dan's suggestion was worth a shot but still no worky worky.
So, what's easier, taking stuff apart to look at the heater/AC door, or taking stuff apart to try the RMW HVAC module?
Or any other suggestions?
FUN-9C1
FUN-9C1
PostSubject: Re: 95 FWB HVAC question- no heat, no A/C   95 FWB HVAC question- no heat, no A/C EmptyTue Nov 19, 2013 5:45 pm
Holy cow, I was just looking at my FSM and I don't think "module" was the word I wanted to use!! That looks like a PITA! I was under the impression it might be the controller (that's the word I meant to use)- the display and buttons unit. Is that what you were talking about, Bill?
PostSubject: Re: 95 FWB HVAC question- no heat, no A/C   95 FWB HVAC question- no heat, no A/C EmptyTue Nov 19, 2013 6:47 pm
You can remove the middle bezel around the radio and climate control and swap that pretty quickly. You might be able to access the blend door motor from inside the glove box (behind the compartment)
PostSubject: Re: 95 FWB HVAC question- no heat, no A/C   95 FWB HVAC question- no heat, no A/C EmptyTue Nov 19, 2013 8:15 pm
Yeah Rob, I meant the control panel. easy to get out of both cars...
PostSubject: Re: 95 FWB HVAC question- no heat, no A/C   95 FWB HVAC question- no heat, no A/C EmptyWed Nov 20, 2013 12:08 am
I have a bolt in already modified roadmaster climate contol for sale oculus interested. (instead of destroying a good one)
It is a perfectly good working climate control. Came from my own car,
PostSubject: Re: 95 FWB HVAC question- no heat, no A/C   95 FWB HVAC question- no heat, no A/C EmptyWed Nov 20, 2013 3:24 am
Also check the vacuum manifold block under the passenger side of the dash. I had a line come loose but not off once and it caused no heat.
miniz33
miniz33
PostSubject: Re: 95 FWB HVAC question- no heat, no A/C   95 FWB HVAC question- no heat, no A/C EmptySat May 31, 2014 12:09 pm
Theres a procedure to have the climate control head do a sweep of the potentiometer in the blend door, I have the fleetwood manual with the procedure if you want me to post it? It should tell you the difference in desired position vs actual. My fw also has a 126, as did my last one and it didnt effect the A/C output if it makes you feel better. I'm leaning towards a failed actuator.
EDIT: Also forgot to mention mine, same codes, it was cured after I recently did one ground wire upgrade and the problem was solved! I bought a side post extended from autozone and a 19 inch 4 gauge weatherproof tractor battery cable, made an extra ground to the chassis where the battery cables clip to the frame, used a pre-existing bolt. Try it, it'll only cost 15 dollars, cut my ground side resistance by more than half. If only I can get it to idle now...
» ST-120 and Heat question
» Roadmaster climate control/ HVAC problems
» HVAC/R
» BtB size question
