Need info on manual transmission swap.. EmptyWed Oct 19, 2022 1:27 pm by scot
Need info on manual transmission swap.. EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Need info on manual transmission swap.. EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Need info on manual transmission swap.. EmptyFri Sep 24, 2021 9:53 am by ElKy
Need info on manual transmission swap.. EmptySun Sep 19, 2021 6:22 pm by black blur 96
Need info on manual transmission swap.. EmptySun Jun 20, 2021 11:37 am by scot
Need info on manual transmission swap.. EmptyFri Jun 11, 2021 10:41 am by scot
Need info on manual transmission swap.. EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Need info on manual transmission swap.. EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
3 posters
PostSubject: Need info on manual transmission swap..   Need info on manual transmission swap.. EmptyMon May 19, 2014 2:36 pm
Ok so first off I'm not sure if this is actually going to happen or not, I'd like to gather as much info as possible before making a final decision.
Since the '92 has pretty much a whipped engine and a leaking 4l60 trans I've decided to stuff a 350 into her in place of the little L03. I bought a kit so the tv cable will work with the square bore carburetor I'm gonna run so using the automatic would be fairly easy aside from having no TC lockup.
I have a wonderful super t-10 4 speed trans just sitting in the corner. I already have the flywheel, pressure plate, and clutch.
My problem lies with the clutch pedal assembly..
FIRST I do NOT want to run a t56.
Second, If I can get away with it I DONT want a hydraulic clutch setup if I don't have to.
Is it possible to run an old school mechanical clutch pedal linkage on our cars?
I have a complete pedal assembly and all linkage from my old c10 could this be made to work?
Has anyone ever done a mechanical clutch in a 91-96?
PostSubject: Re: Need info on manual transmission swap..   Need info on manual transmission swap.. EmptyMon May 19, 2014 2:53 pm
I have read the reason you can't is due to the inner fender liner. This could be a myth however......I have a document detailing a T10 swap in a box body car using all 2nd gen camaro linkage and pedals
PostSubject: Re: Need info on manual transmission swap..   Need info on manual transmission swap.. EmptyMon May 19, 2014 7:00 pm
Cutting isn't a problem! And I have NO fender wells at all.
PostSubject: Re: Need info on manual transmission swap..   Need info on manual transmission swap.. EmptyMon May 19, 2014 7:24 pm
Something told me you won't have a problem with cutting metal...
Interesting part will be rigging up the speed sensor to the t-10 to run the speedo....
https://www.dropbox.com/s/ubhngruiadote4r/capriceclutch.doc
and lol
Need info on manual transmission swap.. 859c1clutch_zpsa7d7aa4f
I didn't come up with this doc, I came across it in searching. Thats my disclaimer
PostSubject: Re: Need info on manual transmission swap..   Need info on manual transmission swap.. EmptyMon May 19, 2014 9:00 pm
I'm using a mechanical speedo so I'm just gonna hook up the speedo cable to make it work.
I was concerned with the placement of the pivot. Because in the c-10 the frame was like a C shape there.
On the caprice it's a solid tube chassis in that area.
PostSubject: Re: Need info on manual transmission swap..   Need info on manual transmission swap.. EmptyMon May 19, 2014 10:57 pm
PM sent
» Want a manual transmission in your big b?
» transmission interchange
» wtb transmission
» Haynes manual
» S10 Manual Steering Box
