94 to 96 9C1 rear end into a 84 Impala EmptyWed Oct 19, 2022 1:27 pm by scot
94 to 96 9C1 rear end into a 84 Impala EmptyTue Oct 18, 2022 8:58 pm by silverfox103
94 to 96 9C1 rear end into a 84 Impala EmptyTue Sep 28, 2021 11:01 pm by silverfox103
94 to 96 9C1 rear end into a 84 Impala EmptyFri Sep 24, 2021 9:53 am by ElKy
94 to 96 9C1 rear end into a 84 Impala EmptySun Sep 19, 2021 6:22 pm by black blur 96
94 to 96 9C1 rear end into a 84 Impala EmptySun Jun 20, 2021 11:37 am by scot
94 to 96 9C1 rear end into a 84 Impala EmptyFri Jun 11, 2021 10:41 am by scot
94 to 96 9C1 rear end into a 84 Impala EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
94 to 96 9C1 rear end into a 84 Impala EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
1A2 Service Wagon
6 posters
1A2 Service Wagon
PostSubject: 94 to 96 9C1 rear end into a 84 Impala   94 to 96 9C1 rear end into a 84 Impala EmptyThu Jun 27, 2013 10:07 pm
Hello guys. I just installed a complete rear end from a 95 9C1 into my 1984 Impala. (In fact I installed the complete front/rear suspension into it). As suspected it went in without any issues. However I can't seem to find a set of emergency brake cables that will work. I though I could simply install a set for a 95 9C1...but they are too long. Anyone run into this problem? And if yes what was your solution?
Thanks in advance.
PostSubject: Re: 94 to 96 9C1 rear end into a 84 Impala   94 to 96 9C1 rear end into a 84 Impala EmptyThu Jun 27, 2013 10:47 pm
I'll take some of those blue interior parts you have from Andrew for an answer to your question Wink
JK. Matt (1984twodoor) I believe would have your answer. As he is installing an ss rear into his 87 restoration. It might be in his thread. But, why bother search, right??
PostSubject: Re: 94 to 96 9C1 rear end into a 84 Impala   94 to 96 9C1 rear end into a 84 Impala EmptyFri Jun 28, 2013 10:00 am
Did you adjust it out all the way?
PostSubject: Re: 94 to 96 9C1 rear end into a 84 Impala   94 to 96 9C1 rear end into a 84 Impala EmptyFri Jun 28, 2013 12:52 pm
Why would anyone do that, your always so eager to help! Cool
PostSubject: Re: 94 to 96 9C1 rear end into a 84 Impala   94 to 96 9C1 rear end into a 84 Impala EmptyFri Jun 28, 2013 3:06 pm
....in and out
....face palm
1A2 Service Wagon
PostSubject: Thanks for the replies   94 to 96 9C1 rear end into a 84 Impala EmptySat Jun 29, 2013 10:32 am
Yes its adjusted all the way...the difference in length is over half a foot not something that could be compensated by adjustment.
I did try the search function...and it did not turn up anything of value. That's why I then asked the question. I don't know about other people on here, but time is not something that I have an abundance of...this is why I find it best to ask a direct question and hope for a direct answer.
Thanks
PostSubject: Re: 94 to 96 9C1 rear end into a 84 Impala   94 to 96 9C1 rear end into a 84 Impala EmptySat Jun 29, 2013 1:15 pm
I think Matts away on vacation or something
He probably HAS looked into this as he's installing an impala rear.
Hang tight & he'll help I know
PostSubject: Re: 94 to 96 9C1 rear end into a 84 Impala   94 to 96 9C1 rear end into a 84 Impala EmptySun Jun 30, 2013 11:55 am
I figured I could just use the cables like he did. Now we are both searching I guess. I really wasn't concerned with cables at this point in time. I really just need body on frame and frame completion before the little $hit starts.
Back from vaca now btw
1A2 Service Wagon
PostSubject: Up Date   94 to 96 9C1 rear end into a 84 Impala EmptyTue Jul 16, 2013 7:40 pm
Well, I figured it out. You need to get the "link" from the newer car. In my case I used one from a 95 Buick Roadmaster. I don't have any pictures yet, however I will get some and post them. In the end, all of the parts from the 94 to 96 9C1/SS swapped over just fine.
» WTB Impala SS rear end
» Impala Parts
» Caprice or Impala Rear End
» 1994 SS Impala rear end
» WTB: 96 IMPALA REAR WHEELWELL TRIM
